I think the previous owner wired in Trailtech Vapor wrong
2 replies to this topic
  • TRexCantFap
Posted October 25, 2015 - 10:20 AM
2005 WR450. The previous owner has the trailtech wired up to the button that you press to turn the battery on. When the engine is on the trailtech turns off. Does that button lose power when the engine is on? What would be the best place to wire it up?
  • Krannie McKranface
Posted October 25, 2015 - 03:40 PM
Wire it directly
You must have a fresh battery even if its hard wired
The unit will go to sleep if it has nothing to do, unless it is a voyager unit, which has tach metering.
Download the instructions from Trailtechs website
  • still2smokin
Posted October 26, 2015 - 05:40 PM
The PO wired it to the little light on the switch , that light goes out once the engine starts .
Tap in here V V and it will work fine . Pos wire on the Vapor to the brown wire going to the main switch.
Edited by still2smokin, October 26, 2015 - 05:42 PM.
