07 YZ 450 Oil Housing Time Sert
3 replies to this topic
  • nhoj_yelbom
Posted October 23, 2015 - 07:00 PM
i have installed a heli coil temporarily, cant find any time cert thread repairs local. the kit for M6x1.00 comes with 9.4mm insert, is this the proper length to block the oil drain hole? thanks
Posted October 26, 2015 - 06:39 AM
Measure from the face of the sealing surface down the hole to just past the drain passage (use a piece of wire as a gauge and measure that).  If 9.4mm isn't long enough, plug the passage with a steel ball as per this link:
http://www.thumperta...ter-cover-bolt/
  • nhoj_yelbom
Posted October 26, 2015 - 09:36 PM
thank you, was trying to leave it put together without disturbing the short helicoil thats in there, guess i will get the kit with 9.4mm and order couple of the next size longer also.
  • nhoj_yelbom
Posted October 30, 2015 - 11:36 PM
the 9.4 is too short, go with the 12mm
  • 0 replies
  • Hot  79 replies
  • Hot  33 replies
