2016 YZ450F
25 replies to this topic
  • jimbopitts
Posted October 26, 2015 - 04:03 AM
#21
Why would you buy a hour meter if with gtyr tuner you can see your engine run time?
Hour meters are cheap, why not?
  • jcross312
Posted October 26, 2015 - 07:35 AM
#22
Plus its alot easier to see a meter than to have to plug your tuner in all the time. As for braces, I ordered the unabiker ones. They look very solid and a pretty good deal too. Havent put them on yet though.
  • BGoyins
Posted October 26, 2015 - 07:46 AM
#23
GTYR and Works Connection are virtually the same. I've used both and they are fine for certain tip overs. However, they will bend nicely along with the radiator in many crashes. If you go with "cage" type braces you will probably find the shrouds won't fit as well and the plastic louvers may not work at all. And that may be fine for what your needs are.
  • burp
Posted January 23, 2016 - 07:19 AM
#24
What's a good brace ? Seems like a few options out.
Gytr or is there better options?
I would check out UNABIKER radiator braces. I put these things on my 2015 and their virtually indestructible. I have had a few pretty good wrecks and these things never budged. I will admit they were a bit tricky to put on but they were worth the effort knowing the rad's would never bend!
http://www.unabiker....ant=11082566470
Edited by burp, January 23, 2016 - 07:29 AM.
Posted January 23, 2016 - 09:55 AM
#25
I don't know about "never", but you're certainly not going to bend a radiator every time the bike falls over.
The "brace" types are less protective than the cage types such as the Unibiker in general.
  • braaap970
Posted January 23, 2016 - 07:27 PM
#26
Bulletproof radiator guards. Watch the videos on the website or YouTube
  • Hot  33 replies
  • 5 replies
  • Hot  79 replies
