2005 WR450 Engine failure, parts compatibility?
11 replies to this topic
  • Spam16v
Posted October 20, 2015 - 03:03 PM
Locked up transmission, top end is still salvageable. I understand 2003-2006 are very similar. If I buy a bottom end out of another year, will the top end cooperate? There an 03 and 04 bottom end going for around $800 less the jug/head on FleaBay is why I ask. Secondly, if I do source just the used transmission shafts and gears, which years would I be limited to? Hunted through all the FAQ's and Wiki's I could find but am still a bit uncertain. Thanks everyone.
  • Doug06fx4screw
Posted October 20, 2015 - 03:46 PM
Why not split your bottom end and rebuild it? It would likely be much cheaper. Not sure what years interchange but I would buy new parts. Can't bear the thoughts of rebuilding with used parts. Just my thoughts.
Edited by Doug06fx4screw, October 20, 2015 - 03:50 PM.
  • Spam16v
Posted October 20, 2015 - 04:13 PM
I'd be buying a rack of gears as hard parts and replacing all the consumables IE: Bearings, gaskets, clips etc with new. OEM Gears and shafts gets out of hand pretty quickly. I'm going to evaluate the bike for purchase, entire engine is organized in boxes and doing some ROI estimations if it's viable to put it back together and end up on top or not. For ease of assembly, a used bottom end would be easiest pending price and availability. Second would be a a loose trans used, and a bearing kit and gaskets. Next pending how much is bad, is a few gears, shafts, etc as needed and consumables.
  • still2smokin
Posted October 20, 2015 - 04:31 PM
I have a 05 good lower end .
The timing jumped because the chain rub
block under the valve cover came off
and ended up between the timing chain and cam gears ......destroyed the head and piston .IMG3212_zpsd1d7954c.jpg
http://www.thumperta...-today/page-162
Lower end and cylinder are still good .....PM if interested .
Edited by still2smokin, October 20, 2015 - 05:46 PM.
  • Spam16v
Posted October 20, 2015 - 05:45 PM
.Sent you a note with my email. Thanks -Zac
  • bikedude987
Posted October 21, 2015 - 06:03 AM
likely, only a gear or two are bad in your trans, so replacement wouldn't be too bad.  I would still split cases and evaluate before you buy anything, assuming you are capable.
  • Spam16v
Posted October 21, 2015 - 11:24 AM
Engine has been opened up fully it's a complete garbage can in the transmission
  • DRDP
Posted October 21, 2015 - 12:10 PM
I'm looking for a good set of cases
  • Spam16v
Posted October 21, 2015 - 12:25 PM
Going to look at it Thursday, I have Still2Smokin's bottom end lined up pending purchase, if it all works out, I'll gladly sell you the extra cases to defray the overall cost.
  • bikedude987
Posted October 22, 2015 - 06:46 AM
Wow, you really grenaded that bish.
  • still2smokin
Posted October 23, 2015 - 05:12 PM
:thumbsup:
:ride:  Braaaaaaap .
  • Spam16v
Posted October 23, 2015 - 06:04 PM
Sent you a PM as I have a set of cases available with any ancillary extras you may need.
Plastics plus that tote of goods and its game on!
