2001 YZ426 Intake Valve Lifter is tight
3 replies to this topic
  • YZ Yankee
Posted October 20, 2015 - 02:14 PM
Hey... I was re-assembling my top end, after changing valve springs, and noticed that one of the intake valve lifters had alot of friction going on. I actually needed to grab it with some pliers to pull it back off! That is not something that caught my attention during dis-assembly.
I actually tried some of the other lifters to see if it made a difference, it did not. Nothing seemed to be touching. I thought maybe the valve spring was slightly wider or perhaps the blue identifying "paint" was sprayed on a little thicker.
I tried working it on and off, with a little motor oil for lube. Seems to be better.
Any insight on this? Could this be a problem?
Thanks for your input. This is my first engine breakdown.
Edited by YZ Yankee, October 20, 2015 - 02:17 PM.
Posted October 20, 2015 - 02:42 PM
You returned each of the lifters to their original bores, didn't you?
If not, take the tight one and find which of the 5 holes it fits best into.
  • YZ Yankee
Posted October 20, 2015 - 04:23 PM
I believe it is in the original spot. To see if it made a difference, I did put on of the others in the same hole and it was tight there also. That's why I thought, perhaps it was a tight fit around the valve spring. Maybe the finish on the valve spring was the issue. There is visible clearence around the lifter.
Posted October 21, 2015 - 06:29 AM
Look for a ridge at the top edge of the lifter bore where the cam bore cuts across it.  If not that, I'd recommend you get an eyes-on inspection from a machinist to see what's up.
  • 10 replies
  • Hot  30 replies
