2007 wr 450
5 replies to this topic
  • thomas liles
Posted October 08, 2015 - 07:50 AM
I hit starter button and get one click from relay. sometimes it starts on second push and sometimes it takes a few tries. Starts strong and it's a new battery. I had found wires loose on relay under seat a while ago. Should I check voltage when I hit button?
  • stevethe
Posted October 08, 2015 - 09:53 AM
If it just clicks check for 12.7-13 volts at the battery. Then you can check for the same voltage at the starter bolt. If it has good voltage and the starter doesn't move its usually the starter.
  • thomas liles
Posted October 08, 2015 - 10:02 AM
Ok I'll check it out. I'm going to jump the relay also and check grounds. Thank you!
Edited by thomas liles, October 08, 2015 - 11:49 AM.
  • Krannie McKranface
Posted October 08, 2015 - 06:55 PM
The WR has a 'issue' sometime of not starting if at top dead center.
Usually you just try a couple times till it gets over the hump, and it starts.
  • thomas liles
Posted October 08, 2015 - 07:15 PM
Well that's what I thought it was at first and maybe it is?but it has done that one time to me and I couldn't kick it over but now when I get the single click I can kick it over easily.
  • thomas liles
Posted November 14, 2015 - 04:28 PM
Update. I installed a new relay and has been working good for past few weeks.
