2016 yz450fx just released
Yamaha YZ450F
107 replies to this topic
  • GHILL28
Posted October 08, 2015 - 09:40 AM
#41
I added a WR 4th and 5th gear to my transmission and ended up dropping to a 13/50 from a 13/48.  The thing runs over 80 with ease, and cruises at 60+ happily.  I don't think you'd be looking for 6th very often with an X.
Any gaps in the gears?  2nd-3rd?
Posted October 08, 2015 - 10:14 AM
#42
Not really.  1-3 are stock.  The WR 4th happens to be the same ratio as the 4th gear in the 4 speed YZ450 was, so what you have is the old 4 speed, then add 5th.  Works out really nice in the desert, especially with the Rekluse to make 1st easy at low speeds.
  • Mutley53
Posted October 08, 2015 - 06:19 PM
#43
They will have a kick start removal kit claiming 15 lbs weight reduction. Seems unbelievable to lose that much weight, but if it's true that would put it the same weight as a YZ450F.
https://www.shopyama...0|20&f=2016|277
  • stevethe
Posted October 08, 2015 - 06:22 PM
#44
They will have a kick start removal kit claiming 15 lbs weight reduction. Seems unbelievable to lose that much weight, but if it's true that would put it the same weight as a YZ450F. https://www.shopyama...0|20&f=2016|277
At least they aren't removing the electric start.
  • Krannie McKranface
Posted October 08, 2015 - 06:31 PM
#45
 I love this.
  • 2banga
Posted October 09, 2015 - 02:39 AM
#46
How does the kick start assembly weigh that much!!!
  • beezer
Posted October 09, 2015 - 06:21 AM
#47
I don't see that either.
Posted October 09, 2015 - 06:44 AM
#48
I just like the fact you get a 'free' kickstarter set up when you buy the bike, rather than a $480 dink to add it after you buy the bike, like KTM used to do.
Posted October 09, 2015 - 06:48 AM
#49
I think I can say with a reasonable certainty that it doesn't.  Not all of it put together, including the idler gear.  Maybe 6-7 pounds, tops.
The whole engine is only about 70-75.
  • beezer
Posted October 09, 2015 - 08:23 AM
#50
A kick starter is a really nice thing to have sometimes.
  • highmarker
Posted October 09, 2015 - 11:31 AM
#51
Maybe they used the same scale to weigh the bike as the kick start parts?
5spd vs 6 spd is a no big deal to me IF the total the range in ratios is similar. Especially with bigger motor that pull the gaps easily,
Big tank option's?
YZ have the same stator output reg/rect as the WR?
kickstand?
Edited by highmarker, October 09, 2015 - 02:34 PM.
Posted October 09, 2015 - 01:03 PM
#52
kickstand?
According to the posted article, yes to both.
  • 2banga
Posted October 09, 2015 - 01:51 PM
#53
I have never been close too needing the kicker on my fx. If the unbelievable weight savings are true it puts the 250fx dry weight at 102kg
  • MidlifeCrisisGuy
Posted October 09, 2015 - 02:20 PM
#54
Wish they would have made it a little lighter the Ktm 450xc is listed at 239 lbs no fuel the yz450fx is listed at 262 wet, Gas weight 6.3 lbs per gallons so we can subtract almost 13 lbs for fuel making the yz weigh in at 249 lbs and Ktm runs lithium batteries depending on what battery yamaha used, if they used the ytz7s like in the 250fx that's around another 4 lbs that could be deducted making it at around 245lbs. Would be nice if there was another 6 lbs to be had somewhere to make it a level playing field but I don't know where it would be?
A Yamaha kick stand assembly weighs almost 2 pounds.   ANd the XC doesn't come with a skidplate.   That is about another 1.5 pounds.  6 - 2 - 1.5 = 2.5 pounds left.
  • MidlifeCrisisGuy
Posted October 09, 2015 - 02:29 PM
#55
That is a massive weight saving for removing the kick starter.   It can't be true.
How does the YZ250FX start in gear ?  I fail to see the reason to have an electric starter on a bike if you need to find neutral to use it, especially if it kick starts in gear.
Edited by MidlifeCrisisGuy, October 09, 2015 - 02:30 PM.
  • highmarker
Posted October 09, 2015 - 02:37 PM
#56
I'd bet those weights wrongly listed reflect the weight of the Estart parts and battery, not the kickstart.
  • 53Willys
Posted October 09, 2015 - 02:53 PM
#57
The YZ250FX starts ingear by pulling in the clutch, I have had mine since January and have not used the kickstart yet
Posted October 09, 2015 - 03:22 PM
#58
That would be closer by half at least, I'd say.
Posted October 09, 2015 - 03:27 PM
#59
http://www.thumperta...m/15-wryz-250f/
  • MidlifeCrisisGuy
Posted October 09, 2015 - 03:59 PM
#60
I ask in order to extrapolate to the YZ450FX.
If these bikes are significantly lighter with their kickstarters removed, I'm pretty excited.
  • On January 15, 2017
  • 5 replies
  • Hot  28 replies
