Choke
2 replies to this topic
  • bluefargo
Posted September 26, 2015 - 03:55 PM
My sleeve that the choke lever slides through and which screws into the carb cracked. I have a yz 450 f, 2006. If I wanted to replace this do I need to remove the carb? Is it a simple fix?
Thanks for any input.  Mike
  • Krannie McKranface
Posted September 26, 2015 - 04:46 PM
Well, sort of. Hard to reach....
Yes
#35
Posted September 27, 2015 - 10:04 AM
You shouldn't need to move the carb to replace the choke assembly as long as you can get access to the hex base to unscrew it.  Serviced only as an assembly.
  • Hot  47 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
