WR Speedometer stock settings?
2 replies to this topic
  • DangerRanger245
Posted September 22, 2015 - 04:50 PM
I have a 2015 WR450F. On the multi function display, the front tire size is default at 700mm.
Is this actually correct?
Short of trying to measure a knobby tire...whats the actual outside diameter of the OEM tire?
  • vindog
Posted September 22, 2015 - 09:01 PM
You can make a mark on the tire and the ground and roll it until the line goes all away around and then you x25.4 and that will give you the diameter
  • vindog
Posted September 22, 2015 - 09:14 PM
So I forgot you do all that in inches not mm
