MY 2008 BUILD LIST
18 replies to this topic
  • Krannie McKranface
Posted September 16, 2015 - 08:00 PM
It works reeeeaaaaly well.......
2008 WR450F
CARB MODIFICATIONS:
R&D REMOTE FUEL SCREW
NCJY NEEDLE / 4TH
175 MAIN /  45 PILOT
NEW STOCK NEEDLE JET
BLOCKED ACV WITH 100 AIR JET (2015 CHANGED TO YZ CARB TO REPLACE WORN WR CARB)
50 LEAK JET
AMPUMP TIMED TO JUST MISS SLIDE, SQUIRT FOR (1) SECOND
R&D APUMP LINKAGE SPRING
2008 CRF450R APUMP DIAPHRAGM AND PUSH ROD
ZIP TY HOT START NUT
ERGONOMIC MODIFICATIONS
FASTWAY F3 LOWER PEGS
GUTS RACING TALL/FIRM SEAT FOAM + 1.5” EXTRA
GUTS RACING COMP COVER
BRP SUBMOUNT + 20MM RISER
PROTAPER KX HIGH BARS, STOCK WIDTH
SCOTTS DAMPER
CYCRA PRO BEND CRM MOUNT HAND GUARDS
ZIP TY HOT START LEVER
ASV LEVERS AND PERCHES
CLUTCH LEVER IS LOW-RATIO TYPE
MOTION PRO CLUTCH CABLE
BRAKE PEDAL STOP REMOVED, PEDAL ANGLE CHANGED TO LOW-BOY POSITION
ENGINE MODIFICATIONS
OEM STANDARD WR PISTON, RINGS, TIMING CHAIN AND TENSION-ER (PISTON #4)
2008 YZ EX CAM WITH MODIFIED DECOMP PIN LENGTH
AS RACING STAGE 3 PORT AND POLISH
DUBACH RACING 2007 YZ HEADER
DUBACH RACING FULL STAINLESS MUFFLER AND S/A
DYNATEK FS IGNITION SYSTEM WITH REMOTE SWTICH IN AIRBOX
MODIFIED MAP #2 WITH 5 DEGREES ADVANCE AT ALL RPMS
‘SWISS CHEESE’ MOD CLUTCH BASKET AND HUB WITH STOCK OEM CLUTCH PACK
POLISHED TRANSMISSION (DONE WHEN 4TH GEAR WAS REPLACED DUE TO FLAKING)
BODY
OEM 2012 HEADSHELL
RICKY STATOR H4- HID LIGHTING
OEM 2012 FRONT FENDER
TRAIL TECH ENDURANCE COMPUTER
BRP BILLET ENDURANCE MOUNT
CUSTOM LIGHTING HARNESS BY AS RACING
CA PLATED
1996 HONDA XL DS BAR CLUSTER SWITCH (PUSH BUTTON CANCELING)
SUSPENSION/FRAME/WHEELS
2006 YZ450F FRONT AND REAR SUSPENSION (AND REBUILD)
SKF SEALS FRONT AND REAR
RE-SPRING AND RE-VALVE BY STERIC RACING - .54/6.3
STOCK WHEEL SETS (REMOVED HEAVY TAKASAGO WHEEL SETS)
STOCK TRIPLE CLAMPS (PROTOTYPE DHR CLAMPS REMOVED ; NOT MACHINED RIGHT ANYWAY)
BRIDGESTONE M403 90/100 FRONT TIRE
KENDA PARKER DT-II 120/100 REAR TIRE
BRIGESTONE UHD TUBES
OLD INNERTUBE CUT FOR WIDE RIM BAND
MOTION PRO STAINLESS FRONT BRAKE LINE
EBC CARBON-X PADS
102MM REAR SAG / 38 MM FRONT SAG
TMD SKID PLATE
TMD SHARK FIN
TUSK OS 260MM FRONT DISC
TUSK REAR DISC
DID VT2 CHAIN
OEM REAR SPROCKET (13,14/51)
ELECTRICAL
HIGHWAY DIRTBIKE OVER/UNDER SWITCHES (START AND KILL)
RICKY STATOR REWIND (130 W)
LED TURN SIGNALS WITH ELECTRONIC FLASHER
LED REAR TAIL LIGHT WITH REAR BRAKE SWITCH
BATTERY TENDER PIG TAIL
SHORAI 12AH BATTERY
  • RockerYZWR
Posted September 17, 2015 - 06:33 PM
Nice wheels.
  • woods-rider
Posted September 17, 2015 - 07:03 PM
Is that a paved OHV staging area parking lot? If so, I have never seen one of those before.
Posted September 17, 2015 - 07:56 PM
Gigantic paved parking area, Visitors center with fascinating information for the visitors, huge Toiteys, benches, nice clean trash cans, and a view of the Freeway.
It's paradise.  No need to go riding, really, with all this at your finger tips.
Make a day of it.
Camp right here.
Work on your bike, and test the rev limiter a few times, before it's warmed up, and do limp wheelies around the other trucks.
You can play music that was hard to ignore in 1986 and even harder now.
Like I said. Paradise.
  • 270winchester
Posted September 19, 2015 - 08:17 AM
That's a nice bike. You got mega hours invested in to that thing. What tank is that? I didn't see it on the list.
  • woods-rider
Posted September 19, 2015 - 12:11 PM
Got a link to the Swiss cheese mod? I'm curious to see what that is.
Posted September 19, 2015 - 12:33 PM
I can't remember who did it.....WRFRowdy perhaps?
  • woods-rider
Posted September 19, 2015 - 03:47 PM
Have any pics of the finished product or an explanation on what it's supposed to accomplish and how?
Posted September 19, 2015 - 03:56 PM
No and no
There is a post about it, but I can't find it right now......some one might chime in.
  • foggy3061
Posted September 20, 2015 - 01:05 AM
I think this is the Swiss cheese clutch thread you guys want:
http://www.thumperta...7#entry12648428
  • 270winchester
Posted September 20, 2015 - 05:55 AM
Krannie, is that an IMS tank?
Posted September 20, 2015 - 07:16 AM
Yes
3.2 I believe
  • Chaconne
Posted September 20, 2015 - 05:54 PM
Make a day of it.
Camp right here.
Where is that? No place like that East of the Mississippi for sure.... Sweet ride BTW.
Edited by Chaconne, September 20, 2015 - 05:56 PM.
Posted September 20, 2015 - 06:11 PM
Hungry Valley OHV, Gorman Ca.
We don't ride in the OHV park, we go above it into the Forest.
Here's some pics from yesterday and beyondIMG_0995_zps8e863fc2.jpg14695127197_2e8c716ca7_c_zpsc4d8b9f4.jpgIMG_0272.jpg51212LPNF030_zps8ad3aada.jpg:
  • Chaconne
Posted September 21, 2015 - 11:25 AM
Awesome. :ride:
  • Summit
Posted September 21, 2015 - 02:24 PM
Nice bike, neat staging area, great looking terrain too. Makes me think California might not be all bad.
Posted September 21, 2015 - 02:26 PM
It's not all bad.
It only takes about 7 or 8 years to figure out where NOT to go in CA, to make it pleasant.....and that goes for everything here in CA.
If you follow the popular trends, it's the worst place on the planet to be.
  • Chaconne
Posted September 21, 2015 - 03:28 PM
It's not all bad.
All places have their pluses and minuses. Lived in lots of places and CA is still near the top in my book.
  • DangerRanger245
Posted September 29, 2015 - 08:26 PM
The land is great. The politics and taxes suck.
