Water Pump Issues Corrected?
6 replies to this topic
  • ewr2004
Posted September 13, 2015 - 07:22 PM
Can someone in the know inform me if the water pump issues have been corrected, and if so, beginning with what year?
Edited by ewr2004, September 13, 2015 - 07:23 PM.
  • Krannie McKranface
Posted September 14, 2015 - 05:28 AM
What issues?
I've owned WR's since 2003 and have never had nor heard of a water pump issue.
Starter, yes.
Edited by KRANNIE, September 14, 2015 - 05:28 AM.
  • RMK800
Posted September 14, 2015 - 11:11 AM
You do have to replace your water pump seals every so often, but that is standard maintenance. I've done it once on my 2007.
  • WRF-Rowdy
Posted September 15, 2015 - 12:35 AM
What issues?
Ditto. Neither the WR400F, nor the 2003 WR450F I owned for +20.000 and +15.000 miles repectively
had any water pump issues, e.g. unchanged from new, no maintenance necessay.
  • foggy3061
Posted September 15, 2015 - 03:25 AM
Some of the early aluminium frame bikes suffered from a water pump seal leak. Displayed as a drip from the hole below the water pump.
All of the bikes that had this issue will probably be sorted by now. The pump itself shouldn't be an issue.
  • GuyGraham
Posted September 15, 2015 - 10:47 AM
What was the issue as mine leaks dispute changing the seal a few times?
The shaft is in good condition so I'm thinking balancer shaft bearings now
  • foggy3061
Posted September 15, 2015 - 01:37 PM
I was lucky with my bike, just a new seal cured it. The impeller shaft was in good condition too. I was fully expecting to find the shaft worn or perhaps even a crap bearing impeller bearing.
