What could this be - metal piece from sump
5 replies to this topic
  • bigl
Posted September 12, 2015 - 09:47 AM
I drained my oil today and stumbled across this metal piece from the sump.  What could it be part of?
I got some small filings on my magnetic sump plug - not much - it is the first time I used one since 5 hours ago.
The bike has 10k km and now 10.6 hours since fitting an hour meter.
Should I panic and start saving or rebuild?  The bike runs like a charm.
  • Krannie McKranface
Posted September 12, 2015 - 09:55 AM
What is in the oil filter?
  • bigl
Posted September 13, 2015 - 07:58 PM
I will be doing a full change in five hours time and see.  After the initial panic, I have thought quite a bit on the 'burr'.  Although I am reasonably sure I bumped the oil catch tray to get rid of possible foreign matter, there is a chance the burr was in there before I started.  I just cannot see that thing draining easily through the sump drain threads.  Also, it is rusted.  If it came from the engine, it should be shiny right?
Posted September 14, 2015 - 04:47 AM
I would pull the filter now and check it.
  • bigl
Posted September 14, 2015 - 09:38 AM
Thanks.  Will do.
  • bigl
Posted September 16, 2015 - 07:43 PM
I pulled the filter last night and it had a couple of fine aluminum flakes - definitively not magnetic.  I guess this is where I take it on faith that the 'burr' was stuck to the oil catch can before I started.  Wish me luck :)
