Starter motor?
9 replies to this topic
  • bopper450
Posted September 06, 2015 - 08:48 PM
Hey guys I have all the must have mods done to my 12 wr 450 and also had the co set by my dealer and the bike was a breeze to start with the button for about a year, now recently I pretty well have to kick start my bike in every scenario and nothing else has been changed. Is my starter motor getting weak? What else can you guys think of?
  • JVP
Posted September 08, 2015 - 12:44 PM
The starter relay tends to go bad on the WR's.  Bypass the relay to check the quality of the starter.  If it still good, then your relay is going bad.
  • Spiritwalker2222
Posted September 08, 2015 - 07:27 PM
How fast is the starter suppose to spin the motor? Last time I had my FI tool hooked up to the bike, I noticed that the starter motor would only spin the motor to about 600 rpm. Not sure how fast it's suppose to spin, but I thought it would have been faster. My bike is hard to start when warm, but with my latest adjustments will start right up when in neutral.
  • vlxjim
Posted September 08, 2015 - 07:38 PM
Make sure your battery is good. It may seem good, but only a very good battery will start these bikes.
  • stevethe
Posted September 09, 2015 - 06:49 AM
Never heard of the relay going bad either they work or they don't. Put a Lithium battery in there and be done.
  • DeepPurplishBlue
Posted September 09, 2015 - 09:38 AM
I have 8 WRs from 2003 up and only once has a relay failed and it happened to be on my oldest and
most heavily used bike.   So 11 years and probably 30,000 miles before a failure.   That is a lot of starts.
It was a misleading failure--   it still clicked but no action from the starter.    Might lead you to believe the
starter motor is at fault but jumping a tool across the two 8mm bolts on the relay will tell you if it is the problem
or not.
+1 on the lithium battery.    I put a shorai in my main WR a few years ago and it has worked great.
Try one and you will never want another lead-acid battery.
  • Jon-D
Posted September 10, 2015 - 06:57 AM
all the above and check voltage at starter when you push the button to make sure you getting all the juice.  also check connections.  I had a similar problem with my KTM turned out a couple of wires developed some corrosion which resulted in a voltage drop to the starter.
  • Krannie McKranface
Posted September 10, 2015 - 02:20 PM
I would say the number 1 reason for bad starting action is a bad battery, and number 2 is a dirty harness or ground.
The stock battery is only 9ah, and only for about the first 100 starts. After that it's amperage drops quickly.
Shorai recomends a 12ah battery as a MINIMUM for best starting.
  • bopper450
Posted September 12, 2015 - 04:12 PM
If I were to order a shorai is there a part number for replacement fit for our bikes ?
Posted September 12, 2015 - 04:45 PM
Go to their site and enter your bike info
