2010 Yzf 450 help
6 replies to this topic
  • Bikerboy
Posted September 05, 2015 - 11:25 AM
if I kick start it without the choke it bearly starts if I pull it out it kicks first time then leave it running on the choke for 5 minutes to warm up push it in and as ur snouts to set of and rev it it cuts out not always but most times doesn't not do this if I set of with the choke out its like it seems like it wants to be ridden in the choke what's the cause of this ?
  • Monk
Posted September 05, 2015 - 11:32 AM
Sounds lean on the bottom...
And you don't have to let the bike warm up for 5min. Maybe a 1min at most...
  • William1
Replace the pilot jet.
Bike should always need the 'choke' on cold starts.
  • billygildark5007
Posted September 05, 2015 - 01:31 PM
Umm... A 2010 doesn't have a "choke" or a pilot jet.
Are you sure your idle speed is correct (1950-2100rpm)? It's adjusted by turning your "choke" (cold start).
  • defilmcrew
Posted September 07, 2015 - 02:49 PM
Reset your idle and go from there sounds way too low
  • defilmcrew
Posted September 07, 2015 - 02:54 PM
Pull the knob out let it run for 1 to 2 mins and push the knob in. Set idle to 2100 to 2200 rpm and ride it. most of the time when the bike is ridden hard or as the engine gets hotter the idle will drop even further down around 1800 to 1900 which may flame out down low so try to shoot for 2000-2100
  • Orvis309
Posted September 09, 2015 - 09:12 AM
Idle should be high enough to start off without touching the trottle, these bikes don't like a low idle
  • 5 replies
  • Hot  28 replies
  • Hot  38 replies
