2006 WR 450 pilot jet ?
6 replies to this topic
  • hyamsj
Posted September 03, 2015 - 03:47 PM
I picked up this bike not running after going over the carb about 5 times it is running but the pilot
Screw is out 3.4 turns with a 48,everything I have
Read here a 48 should work? The air pump is removed
New needle and the carb is clean!
  • beairmo
Posted September 03, 2015 - 04:06 PM
48 should work but 45 is what I ended up with.
Has the airbox been modified? Like the top being cut out like a YZ airbox?
  • hyamsj
Posted September 03, 2015 - 04:30 PM
The snorkel is removed
  • William1
Posted September 03, 2015 - 04:34 PM
45 pilot is all it should need. Air box mods make no difference at idle.
Check the vacuum release plate, make sure it is in square side down.
Check the hot start, make sure it seats properly.
  • hyamsj
Posted September 03, 2015 - 04:42 PM
I did not think about the hot start. I will look in the am.
  • bobpara
Posted September 04, 2015 - 07:25 AM
What altitude (approx) are you at?
Average ambient temp in your area?
  • hyamsj
Posted September 04, 2015 - 07:56 AM
We are at sea level 85-95,I may have found the problem my tank check valve is not working l am at two turns and running good
