damper assy
3 replies to this topic
  • markjo2013
Posted August 30, 2015 - 06:32 PM
will damper assy from  2005 wr450f fit 2003    what years will fit   plus cover assy
  • Krannie McKranface
Posted August 30, 2015 - 06:58 PM
Fork?
Shock?
cover ?
  • markjo2013
Posted August 30, 2015 - 07:34 PM
torque limiter and cover
  • DeepPurplishBlue
Posted August 31, 2015 - 02:30 PM
For the starter motor?
Yes, it will fit.    Note that unless you also use the 2005 stator cover there is a bushing you need to install in the stator
cover because the diameter of the shaft of the damper is smaller than the shaft of the idler gear of the 2003.   The part
number escapes me at the moment but it shouldn't be hard to find if you search the other starter upgrade threads.
