Help with brake light
No replies to this topic
  • pooch20
Posted August 29, 2015 - 03:19 PM
Im trying to set the oem tail light up as a break light on my 07 450. everything I've searched says hook the pressure switch up in the yellow wire that comes out of the connector. Problem is I don't have yellow. PO had it set up to have a brake light but the wires severed off the pressure switch and i have not been able to find them. The female connector going into the main harness has blue/white, green, and white. The male connector has green, white, and light blue.
This is my connector:
Edit: also doesn't appear to be anything tapped into the positive lead of the battery to supply the needed 12v to the pressure switch so thats not helping to track down any wires
Edited by pooch20, August 29, 2015 - 03:32 PM.
