WR450 FI Tool
26 replies to this topic
  • Slow and Jerky
Posted August 20, 2015 - 05:36 AM
I am looking to buy the FI tool for my WR so I can adjust the CO2 but I am having some problems finding it. I found this on Amazon but cannot find anything to indicate if this works for my bike.
http://www.amazon.co...623860_70668670
Anyone have an idea if this is the correct tool?
  • nucular
Posted August 20, 2015 - 09:31 AM
That looks right. I think there is only one.
  • Krannie McKranface
Posted August 20, 2015 - 01:59 PM
https://www.google.c...6.0.4kyXOX909TY
  • drdanbozeman
Posted August 20, 2015 - 02:07 PM
I purchased the Yamaha branded FI diagnostic tool from http://www.cmsnl.com...2/#.VdZOpniBMUV
Current price 88 Euros = $99.00 and my shipping was about $15
So considerably less expensive than the Amazon seller
  • Slow and Jerky
Posted August 20, 2015 - 04:26 PM
The link  is for the GTYR tuner, is there a way to adjust the CO2 at idle with it?
  • drdanbozeman
Posted August 20, 2015 - 05:55 PM
The GYTR tuner is for adjusting the fuel and ignition maps, not for setting CO [carbon monoxide not carbon dioxide] levels.
Tuner functions explained pretty well here : https://www.rockymou...YTR-Power-Tuner
  • Slow and Jerky
Posted August 20, 2015 - 06:16 PM
That's what I thought, have used the GYTR. I went ahead and ordered one from CMSNL, do you remember how long it took for yours to get to you?
Posted August 20, 2015 - 07:39 PM
So, that diagnostic tool comes with a widband CO sensor ?
  • chu
Posted August 21, 2015 - 03:14 AM
It doesn't measure CO, just adjusts it.  It's good for adjusting the TPS too.
Posted August 21, 2015 - 04:13 AM
How can you adjust it without measuring it ?
  • drdanbozeman
Posted August 21, 2015 - 05:15 AM
It took about a week to receive from Europe
  • chu
Posted August 21, 2015 - 05:17 AM
Maybe adjust is the wrong word.  You can change it.  I set it to lean best idle.  If you're shooting for a particular CO output maybe a garage would let you use their exhaust gas analyzer.
Edited by chu, August 21, 2015 - 05:17 AM.
  • Slow and Jerky
Posted August 24, 2015 - 07:27 PM
Tool came in today, I'm impressed with how quickly it got here from the Netherlands. What are you guys running yours at? Or maybe what the ideal percentage is? I have access to a sniffer so I can play with it a bit.
  • chu
Posted August 25, 2015 - 04:04 AM
I've got it at -5 currently.  For a car, it looks like CO should be less than 2% with a stoichiometric idle.  Others on here suggested 3% CO, I think.  For me, a rich idle on a fuel injected bike is just a waste of fuel.
There's data here from a couple bikes.  They're probably all a little different.
http://www.thumperta...#entry11771665
Edited by chu, August 25, 2015 - 04:07 AM.
  • Slow and Jerky
Posted August 25, 2015 - 05:03 AM
Just so I am understanding correctly, when you increase (+) the number on the tool it is increasing fuel and going minus (-) is decreasing...?
  • chu
Posted August 25, 2015 - 07:41 AM
Yeah.  I think most people get better electric start with a positive number.  I have to pull the knob for a cold start but I think that's how it's supposed to be.
I have different cams in there, maybe it pulls less vacuum at idle and uses a little less fuel?
Edited by chu, August 26, 2015 - 03:51 AM.
  • Andrew Puetz
Posted August 29, 2015 - 07:01 PM
what is the ideal measurement if I did have a sniffer?
  • puffoxr
Posted August 29, 2015 - 10:38 PM
I'm going to by the FI tool to set properly the CO. I understood that it can also check and set the TPS in case of problems .
My question is: can it be used also for reading errors (better understanding malfunctions), or other service functions or its use is only for setting CO and TPS?
Last questions is if it is a really standard tool for the other yamaha (for example can I use it to set CO also on a super ten?
Thanks a lot to everyone!
Paolo
  • boston460
Posted August 31, 2015 - 03:34 PM
Paolo
Hi Paolo
Yes the diagnostic tool can be used to check fault codes, I can't see why you couldn't use it on a super tenere, I have seen one used on a 660 tenere to adjust the CO.
  • puffoxr
Posted September 15, 2015 - 08:10 PM
For those that bought the FI tool from cmsnl, does it come with the right connectors for the wr?
Thanks
Paolo
