2014 yz450f worn connecting rod
38 replies to this topic
  • DanielMerrick
Posted August 19, 2015 - 07:52 PM
2014 yz450f
58 hours
Hey guys was chasing a new knock/raddle and found a minimal amount of play in the piston pin end of my connecting rod, I've looked in the service Manuel and as far as I can tell they don't list the specification, piston pin is in specs oil change every 2-3 hours, only used yamalube and filters.
Found a rough surface on the pin and connecting rod.
Just looking for some reassurance before I order a crank and piston ImageUploadedByThumper Talk1440042707.161464.jpg
Posted August 19, 2015 - 09:17 PM
It's been rattling just by the look of the pattern on the center area.  The inside of the rod will look just like that. It's been scored, and then the scoring pounded flat on the tops of the high spots.
  • DanielMerrick
Posted August 19, 2015 - 09:38 PM
The rod is a mirror image sadly
Yamaha has updated the connecting rod starting in 2015 curious to what they changed
Going to visit my dealer and se how much this sets me back
  • Bremer120
Posted August 19, 2015 - 09:49 PM
Just had a total rebuild on my 14 for a rod failure at 27 hours. It occurred at the small end. The bike started making a ticking/knocking noise and my friends thought I was crazy and I thought I was too, sure enough the rod broke and took out the entire motor. Yamaha graciously covered parts (equating to around $4000) based on the relatively low hours of the motor and overall condition of the bike. I would say replace and if 15 shows a new part number that would be a good decision.
  • rojapar
Posted August 20, 2015 - 05:26 AM
Edited by rojapar, August 20, 2015 - 08:54 AM.
  • DanielMerrick
Posted August 20, 2015 - 07:15 AM
I'm going to call Yamaha se if they won't do anything, my dealer is willing to give me a good deal on the parts I need but I bough a new bike knowing I didn't need to split the case for at-least 3 years,
  • Bremer120
Posted August 20, 2015 - 08:33 AM
That is exactly my thoughts every time I purchase a Yamaha is that I don't have to mess with high dollar maintenance for a long time. That's why I called my shop the Monday after I blew it up at practice. I would try your hardest to get it covered. I still have the warranty receipt somewhere so I will find and maybe pm you any important transaction number that may help with their research in showing that this is a defective part. I thought mine was a fluke and I never ended up posting my failureImageUploadedByThumper Talk1440088384.690821.jpg
  • DanielMerrick
Posted August 20, 2015 - 08:46 AM
I called customer support and the just of it is if the dealer finds it to be a manufacturing defect they can cover it.
My dealer (who I bought my bike from) is really good with customer care and took my issue seriously.
If you come across that receipt pm please! It would be much appreciated !
  • Bremer120
Posted August 20, 2015 - 08:52 AM
I pm'd you. Unfortunately I just got off the phone with my shop and the service tech, who helped me get it covered, is unable to give out that information (the specific warranty number). However I am going to send you pictures of my receipt with parts, description, and resolution for your shop to mull over. Good luck. Let me know how it goes.
  • drtrcr400
Posted August 20, 2015 - 11:35 AM
2014 yz450f
58 hours
Just looking for some reassurance before I order a crank and piston attachicon.gifImageUploadedByThumper Talk1440042707.161464.jpg
Not trying to point fingers or anything but what oil were you using and how frequently did you change it? I replaced my piston last year at 111 hours and the wrist pin looked perfect...
  • Bremer120
Posted August 20, 2015 - 11:38 AM
The post you quoted states both items you were asking...
  • drtrcr400
Posted August 20, 2015 - 11:45 AM
Damn, I need to start focusing more!
  • Jon-D
Posted August 21, 2015 - 06:46 AM
this is a bummer.  I am riding a Honda currently with tranny problems and tired of dealing with the out of norm maintenance on the bike so I am looking to buy a yz450 because its supposed to be the most reliable, minimal maintenance kind of bike.  what steered me to the yz 450 is I have an 06 yz 250f that I regularly flog and cannot seem to break it (I have tried) which is why I was looking at a new 450.
  • DanielMerrick
Posted September 02, 2015 - 02:42 PM
Well I got all the parts to rebuild my bike plus some,
Crank
Piston pin
New piston
Circlips
Cam chain
All gaskets
Gytr oil nozzle
I'm not sure if the oil nozzle will do anything but I figured if they use it for high compression it must do something, it has 2 leak holes vs the standard 1,
I paid for the extra items and there going to let me know if the crank issue will be warranty,
Anyone se the yxz1000r ? Totally In love lol
Edited by DanielMerrick, September 02, 2015 - 02:42 PM.
  • DanielMerrick
Posted September 02, 2015 - 02:44 PM
Posted September 02, 2015 - 03:04 PM
I'm not either, since it has one already.
It strikes me that the original problem could have been brought on by detonation.
  • DanielMerrick
Posted September 02, 2015 - 03:07 PM
It's highly unlikely I will se anything with this setup but it may help if i boost it this winter,
  • GHILL28
Posted September 02, 2015 - 03:59 PM
Stock mapping?  What kind of fuel?
  • DanielMerrick
Posted September 02, 2015 - 06:04 PM
Hotcams stage 1
Travis Preston modified map
91 mixed with c12 5:1
91 up here is junk
  • Bremer120
Posted September 03, 2015 - 08:47 AM
Glad to hear you're getting your bike back together. I also did the oil squirter while I was in there. Seemed like a good idea. I had people wondering if it was detonation that caused the problem with my bike as well. I hope this wasn't the cause because I haven't changed anything since.
