Weird front sprocket wear
9 replies to this topic
  • bigl
Posted August 18, 2015 - 08:49 PM
Hi
I managed to wear out a front sprocket in +/- 600km.  This seems very excessive even though I like caning the bike - 05 WR450.
This sprocket looks to have the same wear as the set I replaced.  The inside, motor side of the sprocket is very deeply worn, while the outside looks fine.  I checked to see if there are any shim washers in the manual, but see none. ( In case the rear is slightly offset. )
I also replaced the chain adjuster blocks after the last chain set.  The chain looks straight when fitted.
Any ideas?
p.s.  I should have taken photos, I know :banghead:
  • GuyGraham
Posted August 18, 2015 - 11:08 PM
Sounds like chain alignment is out possibly due to rear wheel alignment.
I get 3k miles out of front sprockets and thats all off road use
Edited by GuyGraham, August 18, 2015 - 11:09 PM.
  • bigl
Posted August 19, 2015 - 03:09 AM
So no front sprocket spacer.  Dang.  Does that mean the swing arm is bent or should I find a better way of checking the rear wheel alignment?
  • Krannie McKranface
Posted August 19, 2015 - 05:27 AM
motion pro chain sight alignment tool
  • bigl
Posted August 19, 2015 - 08:18 PM
Thanks.  I am checking it out.
  • jsantapau
Posted August 21, 2015 - 04:34 AM
if you have two different colored wheel spacers check to see if they are not on t wrong side
  • bigl
Posted August 21, 2015 - 11:05 PM
I am not to sure what you are referring to?
Posted August 22, 2015 - 05:24 AM
He's talking about the rear wheel spacers.
  • bigl
Posted August 23, 2015 - 07:42 PM
I thought so, but the parts fiche shows the same part number both sides.
I dug through the scrap metal to get the sprocket to show to a buddy.  I found another friends VTR1000 front sprocket from a set I helped replace a while back.  It had the same one sided wear pattern.  i am now thinking it must have something to do with the torque effect.
  • still2smokin
Posted August 23, 2015 - 08:04 PM
Maybe also check your swing arm bearings .
