06 wr450 backfire problems
4 replies to this topic
  • Mr YumYums
Posted August 10, 2015 - 05:14 PM
I recently bought an 06 wr450f and it has a hmf slip on exhaust installed. The bike backfires sometimes. Is this a big issue? I'm buying a quiet core and spark arrestor insert for the muffler. What exactly should I be rejetting on the carb, if anything at all? Thanks
  • RMK800
Posted August 10, 2015 - 06:41 PM
You need to give us a little more information then that like...elevation. Be a good idea to go through the entire carb to see what you got in there. Backfire is your lean on the fuel screw. You might need to open it up a 1/4 or 1/2 turn. You also could be lean everywhere else like pilot jet.
  • Mr YumYums
Posted August 10, 2015 - 07:07 PM
1300 feet, could the backfire damage my engine though?
  • Krannie McKranface
Posted August 10, 2015 - 07:35 PM
You have a lean condition caused by an air leak.
No reason to change jetting if it ran well before with the jetting you have, unless you went up 8,000 ft......
Fuel screw
Muffler joints
Air boots
EDIT
..corroded and leaking hot start plunger <<<<< very common
Edited by KRANNIE, August 11, 2015 - 05:42 AM.
  • Summit
Posted August 11, 2015 - 04:26 AM
Also check to make sure the little rubber boot on hot start nut is properly seated.
