YZ 450 2011 WHEELS ON A 2014
6 replies to this topic
  • Envisage
Posted August 07, 2015 - 02:24 AM
For memory the front axle is 22mm, but not sure what it is on the 2011, 20 maybe  ?
Anyone know if you can make the 2011 wheels fit the 2014 either by changing bearings, hub internals  etc ?
  • zeuszuki
Posted August 07, 2015 - 10:12 PM
Can be done , I have done it and have run them for 2 years without issue.
Front wheel - You need to source the bearings and machine the 2011 wheel spacer out to 22.2 mm.
Search my article on this on ThumperTalk and post it , I can not for the life of me find it but others on here have.
Rear wheel is a bolt in.
  • Envisage
Posted August 08, 2015 - 07:43 PM
OK, cheers can you remember what you had as the subject ?
By machining the spacer,  you meaning the aluminum spacer that floats in the hub ?
  • zeuszuki
Posted August 09, 2015 - 01:46 PM
Yes, the aluminium spacer that floats in the hub - 22.2mm ID
Bearings - get the verniers out, 2011 OD & 2014 ID
Seals - 2011 OD & 2014 wheel spacer OD as the seal ID #
Hope that makes sense. I would do a measure up but my wheels just do not need pulling down ( packed the bearings with Yamalube grease and have not had to touch them since! ).
  • Monk
Posted August 09, 2015 - 02:13 PM
11 front will not bolt on. 20mm vs 22mm. They don't make a bearing in that oddball size for the 20mm hub. The hub itself had changed to accept the larger bearing for the 2014 model. The rear is a direct bolt on...
  • zeuszuki
Posted August 09, 2015 - 06:42 PM
Well you might want to tell my bearing guy who supplied the bearings that fitted straight in, not to mention that I have been running this configuration for 2 years now.
Maybe you can not get them in the US of A but no problems here in little old NZ !
  • zeuszuki
Posted August 09, 2015 - 06:58 PM
http://shockcraft.co...kit-enduro.html
Here is a link to the bearings I fitted..... waiting for all the experts to jump in and say they will not hold up blah blah blah , well 2 years of abuse says otherwise.
$30 for the whole conversion made it a cheap swap out.
So 22mm ID , 37mm OD for bearings
37mm OD , 30mm ID for seals.
Dug through some old Pm's I had on another forum.
