2016 yz 450 clamp offset
3 replies to this topic
  • Hudman 378
Posted August 05, 2015 - 01:40 PM
Does antone have one and know if a different offset is better on the 16? Everything i read seems to say 20mm is better, then i will read that stock is best?
  • Drenmaster
Posted August 05, 2015 - 02:13 PM
They changed the frame and swing arm so the bigger offset is going to work with the '16 compared to a '14-'15 where people say the 20mm offset helps. sure other people will chime in with a more indepth explanation.
  • 15thumper
Posted August 05, 2015 - 02:31 PM
Ride engineering is testing right now to see which offset is best should be out soon
  • Hudman 378
Posted August 05, 2015 - 10:33 PM
Thanks guys!
