Magura Clutch !
4 replies to this topic
  • humbertob
Posted February 22, 2002 - 11:34 AM
Actually I got a Magura clutch installed in my '99 YZ400F and I want to check the liquid level but I need what to use if the reservoir needs liquid ! Mineral Oil......? What brand.....? Where can I get it......?
Thanks ! :)
  • YZ400Court
Posted February 22, 2002 - 05:03 PM
You can use baby oil from any drug store, or ATF works well also.
  • urla
Posted February 23, 2002 - 06:45 AM
I have been using fork oil 5W for 2 years now.
  • blbainb
Posted February 23, 2002 - 07:44 PM
Fork oil works fine (Yamaho 01). The only problem is bleeding the system properly. I found that I had to submerge the caliper/piston end completely and then open the banjo bolt while squeezing the lever - not easy with one hand! I did get it to work though.
  • urla
Posted February 24, 2002 - 09:12 AM
I remove the slave cylinder piston rod (using a hex-bolt tool on the piston) to bleed the system.
This way I also can "backfill" the system, connecting a tube on the "piston rod hole" whit a syringe.
But I don't think Magura supports that way of doing it, use the link below to find out how magura think it should be done (to cumbersome for me).
http://www.magura.de...oad/befuell.pdf
http://www.magura.de...f_road_main.htm
includes spareparts list, installation and more.
[ February 24, 2002: Message edited by: urla ]
  • Hot  38 replies
  • Hot  28 replies
  • 5 replies
