Anyone run a rear cargo rack? What about this one?
10 replies to this topic
  • tmasWR
Posted July 31, 2015 - 07:18 PM
 I like to pack a couple fuel bottles with me on longer trips. I use MSR red 30oz fuel bottles http://www.backcount...AgPFxoC0zzw_wcBIn the past I would strap them on the back of my camelback.  I have been toying with the idea of running a rear fender rack on my 2014 wr450 to pack these bottles.  I checked out the pro-moto billet ones and they look sharp and solid...i'm just struggling to choke down the ~$190 price tag.
  I ran across this website of a company out of Utah, but haven't found much info about them.  What do you guys think at less than half the price of the pro-moto ones?
http://www.wr-produc...450f-2007-2014
They do look sharp at least.  I think i'll send them an email to find out if they have any pictures of them actually mounted on a bike.
  • tmasWR
Posted July 31, 2015 - 07:20 PM
Sorry, meant to post this on the WR forum.
  • highmarker
Posted July 31, 2015 - 07:23 PM
I use a giant loop mohave, and cheap fuel bottle  Motor oil quarts, 1/2 gal plastic booze jugs, power aide bottle's etc.  Trick is fill them full to top. Any space will build up pressure from the fumes.
  • DeepPurplishBlue
Posted August 01, 2015 - 06:01 AM
http://www.thumperta...argo-rack-2006/
  • tmasWR
Posted August 02, 2015 - 04:06 PM
Thanks, I was looking for a thread like that.
I will order the WRP tomorrow, i'll let you know how it works for me!
  • SurfaceToAir
Posted August 09, 2015 - 12:35 AM
I made a rack for the fender that I strap msr tanks to. But also have soft saddle bags that I also put cans in. The saddle bags are great and I use them more than the rack.
Edited by SurfaceToAir, August 09, 2015 - 12:40 AM.
  • tmasWR
Posted August 09, 2015 - 07:50 AM
Sweet set up, looks like fun country to ride in.  I've wondered about saddle bags, I might need to check some out.  That rack looks cherry for hauling a few lbs as well.  I should have found some time and just welded up my own...still might if I don't like this wrp rack.
My WRP rack got lost in transit, good ol USPS.  Supposed to be delivered on Monday now...not holding my breath.  I'll post up some pics when I get it here and try it out.
  • tmasWR
Posted August 11, 2015 - 04:13 PM
Rack finally got here today.  Overall I think it is pretty slick.  I wish it tapered narrower as it goes back, like the fender( just for a sportier look) It feels solid, should carry a couple fuel bottles snug no problem.  Note, you do have to drill two holes in the fender for mounting...and trim the side fender plastics a bit as well.
  • PacoPaez
Posted August 11, 2015 - 07:50 PM
The wr450 sub frame is not strong to carry a lot of weight on a rack I used one dont matter wich the pressed nuts are too weak if bolt gets loose it damages the nut that holds seat also.
  • tmasWR
Posted August 11, 2015 - 08:20 PM
Thanks for the advice Paco.  Hopefully it will be able to handle the 4-5lbs i'll throw on it in fuel.  Was your problem only happening when the bolts would work loose?
  • PacoPaez
Posted August 11, 2015 - 08:27 PM
Yes on a two day ride in Baja I had tools and heavy duty tube only I admit neglected to check for loose bolts my wr is an 09 aluminum subframe.
