Hard Start and Mild backfire
3 replies to this topic
  • exokiler
Posted July 30, 2015 - 06:52 AM
Hey guys so I finally got the JD JET kit on my bike and I put exactly what they said to put for jets and needle. Bike runs good once started but is hard to start at first *wont start with electric start* and when riding and you let off the throttle it has mild back fire if you down shift.
It was a lot cooler out when I rode yesterday compared to last week when I rode. Maybe need to retune the fuel screw or what?
thanks
  • WRistheWay
Posted July 30, 2015 - 03:57 PM
Have you checked the valve clearances? That can make it hard to start when cold. Also did you change the pilot jet to a different size? If so the fuel screw will definitely need to be re-tuned. You can probably get rid of the backfire by turning the fuel screw out in 1/4 turn increments until you can live with the popping and still maintain a strong idle.
  • Krannie McKranface
Posted July 30, 2015 - 05:30 PM
...back fire, or decelleration popping.
...back fire is literally through the carb.....
Have you installed a R&D remote fuel screw and learned how to adjust it: you seek highest idle with the fuel screw, then re-adjust idle with idle screw, and repeat.
If it takes more than 2 turns out, your pilot is too small.
45p is what you want.
  • Mcflyz450f
Posted July 31, 2015 - 12:52 AM
you can contact them https://www.jdjettin...ction=contactus  they will help you out.
Edited by Mcflyz450f, July 31, 2015 - 12:52 AM.
