Leaky carb 03 WR450
3 replies to this topic
  • toten
Posted July 27, 2015 - 05:45 AM
I realized this morning that my carb seems to be losing a little fuel when parked, I think into the engine. When I turn on the petcock I see fuel flow, which shouldn't happen.
I'm guessing it's the needle, but I could be wrong. Any suggestions on where to pick one up, or what else to replace while I'm in there?? The OEM needle is fairly expensive ($16... a lot for what it is) and in my experience OEM parts take forever to ship.
  • Krannie McKranface
Posted July 27, 2015 - 06:36 AM
visually check the needle and seat for wear
you need to polish the cavity the needle valve sits in to remove any corrosion
you might want to buy a petcock rebuild kit too, as they seem to wear out at the same time
  • toten
Posted July 27, 2015 - 07:49 AM
What would you suggest using to polish it?
Posted July 27, 2015 - 08:33 AM
Brasso brass polish or similar
Polish the needle body too
