Yz450f bad backfire..
17 replies to this topic
  • yzUSMCf
Posted July 16, 2015 - 05:54 PM
Hey guys I have a 2014 yz450f and I have a full DR.D system on it with the map that DR.D provided below(I hear they created this map on the Dyno with an o2 sensor and all). Bike is a beast I like the power but she has bad deceleration poping! My buds even bring it up to me I'll try to upload a video shortly so you can hear. Does it pop because it is lean? Will that cause any harm? I would play with it more but i have to take the bike to a shop to tune as i do not have a tuner ,Thanks!
  • yzUSMCf
Posted July 16, 2015 - 05:56 PM
You can hear it throughout the video.
Watch "PALA RACEWAY: NEW VET TRACK LAYOUT JULY 11 2015" on YouTube
PALA RACEWAY: NEW VET TRACK LAYOUT JULY 11 2015: https://youtu.be/Wdq6y7DGD-o
  • 15thumper
Posted July 16, 2015 - 06:16 PM
I run that map on my 2015 never had any decel pop
  • 15thumper
Posted July 16, 2015 - 06:22 PM
Hard to hear the decel pop over all the dirt hitting the cam from riders passing you, but I've never had decel pop on mine with any map, I'd be checking valves to start with
  • yzUSMCf
Posted July 16, 2015 - 06:35 PM
ouch...my ego..
  • yzUSMCf
Posted July 16, 2015 - 06:36 PM
I'll check the valves .
  • yzUSMCf
Posted July 16, 2015 - 06:40 PM
hmmm...wonder if it was made for the 2015 ECU since the base line is different from the 14' and 15'. Hope someone who has a 14 with this map has any imput . It has been about 10 hrs since I have checked the valves and they had barely moved. But still a good chance they need to be adjusted.
  • rickallen124
Posted July 16, 2015 - 06:43 PM
What fuel are you using? I ask because my '10 would backfire on deceleration when I used gas with ethanol. Never did it with non-ethanol or vp fuel. I'd call Dr.D and ask them about the map, maybe try running all zeroes, stock.
Edited by rickallen124, July 16, 2015 - 06:45 PM.
  • rickallen124
Posted July 16, 2015 - 06:51 PM
If any of the exhaust pipe fittings, or the gasket at the exhaust manifold junction, are loose and not sealing you will have backfiring also.
  • Speeddemon73
Posted July 16, 2015 - 07:04 PM
Like Rick said, make sure to check your exhaust bolts, fittings, and clamps. Make sure everything is tight and sealing correctly. You will get a decel pop if there is an air leak in your exhaust.
Posted July 16, 2015 - 09:08 PM
That would be due to the need to run richer jetting with ethanol; high oxygen content, low energy value.  The more is in the fuel, the leaner it will be.
  • yzUSMCf
Posted July 17, 2015 - 06:32 AM
I will check that aswell
  • yzUSMCf
Posted July 20, 2015 - 04:35 PM
I just checked my valves
Spec. Intake is .13mm to .20mm
Intake is at .15
Spec. Exhaust .20mm-.25mm
Exhaust is at .23
And the bike has 56 hrs on it now. I checked the header bolts they were not loose but could be tightened slightly so I did. The DR.D exhaust dose not use clamps to attach all the pipes and they all look OK.. So I'm not sure
  • yzUSMCf
Posted July 20, 2015 - 04:43 PM
How does this cam chain look to you? Is the rough look normal?
  • 15thumper
Posted July 20, 2015 - 04:58 PM
Have you tried a different map to see if popping goes away??
  • yzUSMCf
Posted July 20, 2015 - 06:12 PM
Yes. And I did but I've been running this map for the last 15 wish hrs or so and it seemed to get a little bit worse. Just wondering it it will cause any harm beside being annoying
Posted July 21, 2015 - 07:05 AM
The exhaust backfire will harm nothing at all.  You might want to see if a little shot of injector cleaner can clear it up, though.  It could be that it doesn't close all the way and is "drooling".
  • ozijake08
Posted September 03, 2015 - 03:56 AM
as a couple of guys have said if the bike is running fine the first thing I would be looking for is a leaking seal/joint in the exhaust system .
if it is a leak in the exhaust system this type of back fire will not harm you engine. ever been to a speedway lately and heard a jawa or a gm backfire when they ease of the throttle a little
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • On January 15, 2017
