Oil Gasket question
6 replies to this topic
  • azorr
Posted July 16, 2015 - 07:14 AM
Quick question, thanks in advance for any help. I am changing the oil for the first time on my newly acquired 02 WR426f. The parts schematic shows a gasket on the crank case drain plug that should be replaced. My plug has a silver washer on it that doesn't come off. Is this the gasket that has been reused so many times its formed on to the plug, or is that part of the plug and there should be a gasket between this and the crank case?
  • Krannie McKranface
Posted July 16, 2015 - 07:16 AM
It should be an o-ring
  • azorr
Posted July 16, 2015 - 07:26 AM
Ah, so there should be a rubber o ring between the silver washer and the crank case? I assumed it had a copper gasket/crush washer like on my truck and on the frame plug.
Posted July 16, 2015 - 07:34 AM
I've never seen a metal crush washer on a plastic filler plug from any  brand.
  • azorr
Posted July 16, 2015 - 07:48 AM
Thank you for your quick responses and for your willingness to help. I am afraid we may be discussing different parts, I apologize that my original question wasn't clear enough. This is the metal drain plug on the bottom of the crank case that is removed through a hole in the skid plate. The gasket in question is number 12 on the attached diagram.
Posted July 16, 2015 - 08:28 AM
Oh sorry
Yes, a COPPER usually crushwasher
  • azorr
Posted July 16, 2015 - 08:37 AM
Oh sorry
Perfect, thanks!
