Advice....clutch drag....
14 replies to this topic
  • soulsedg3
Posted July 13, 2015 - 04:21 AM
So bad gas was the culprit for my hard starts. A little seafoam in gas and starts great.
But....the stalling out....if i turn idle down is due to clutch drag!
I had it in gear....clutch pulled....and it started moving forward on a slight uphill. Thats when it started idling down and stalled out.
Tried again. If i revved...stopped dragging. I adjusted clutch. But it seemsni cant find a in between. Its either dragging or slipping under hard power.
I think i recall someone saying use only oem clutch plates somewhere. Just not sure if that applies to 450s.
Im thinkin plates. Any advice on what kind i should buy?
Posted July 13, 2015 - 06:38 AM
Clutch plates and a set of new clutch springs, so that they let the pressure plate lift straight.
OEM clutch plates work vastly better than the bargain brand aftermarket ones.  Premium plates like Hinson work well too, but may be more expensive.
With clutch drag, you also need to look at the condition of the basket and boss.  Excessively deep "notching" along the splines of the boss or the fingers of the basket can aggravate the condition.
  • RyeMc
Posted July 13, 2015 - 06:42 AM
+1 for notched basket. That's been the culprit when I've have issues in the past.
  • soulsedg3
Posted July 13, 2015 - 06:54 AM
The notched basket would make sense considering the power these things have.
My old cr500 18 years ago was notorious for shredding clutches.
Another question then. If i do have to replace clutch basket, plates and springs....would it not be better to just get a whole new aftermarket clutch setup? Hinson, etc?
Here in canada im looking at 250 for just the plates. Im guessing another 200 for basket.
At that point for another 200 i could go rekluse.
Edited by soulsedg3, July 13, 2015 - 06:58 AM.
  • stevethe
Posted July 13, 2015 - 07:44 AM
I have a very well and long ridden 07' WR450 that the clutch was dragging like crazy. I ended up with Hinson and I believe it drags less than the stock plates that were installed in my sons WR450. I didn't use the Hinson clutch springs in the kit as there were too heavy duty for my tastes. Never touched the clutch basket.
I would go first with the Hinson kit or do stock but don't do the Chinese aftermarket.
By the way it's likely just your steel plates are blue and warped.
Edited by stevethe, July 13, 2015 - 07:46 AM.
Posted July 13, 2015 - 08:12 AM
Those are necessarily stiff.
Use OEM plates.  Aftermarket clutch baskets like the Hinson are good investments, as they are less expensive than the OEM driven gear assembly, and the basket itself is a much more durable piece.  The Hinson boss, however, is about 4 times as expensive as the OEM part, and I don't see that much benefit in it compared to OEM, so if replacing that, stay with stock.
  • soulsedg3
Posted July 13, 2015 - 01:59 PM
Clutch basket looks pretty hammered to my untrained eye.     And i'm not quite sure what to make of the clutch plates....as there are still thickness to em, and aren't flat.   going off memory, i remember they are only truly worn when they are near flat.   The metal clutch plate/spacers dont seem to have any grooves either.
here are some pics...
Posted July 13, 2015 - 02:14 PM
The basket is pretty bad.  Also of some concern is the wear on the face of the boss, as evidenced by the ledge on the plate face (arrow).
The clutch plates don't drag because they get thin, they drag because they aren't flat anymore.  The steels are probably most at fault, and you probably won't be able to pick one out as being very warped, but the set consists of 17 plates, and collectively, all the minor warping adds up.
  • soulsedg3
Posted July 13, 2015 - 02:19 PM
and here are some weird marks on just 2 of my clutch plates.  not sure if it's like a wear mark or not, and if it goes below this, they are bad?
and 3rd pic, shows a small little grove in faceplate.
Edited by soulsedg3, July 13, 2015 - 02:34 PM.
  • soulsedg3
Posted July 13, 2015 - 02:23 PM
So what is your suggestion good sir?   based on what you see.....
(i added two more pics above)
Edited by soulsedg3, July 13, 2015 - 02:24 PM.
Posted July 13, 2015 - 02:41 PM
New set of OEM plates, new OEM boss, and a aftermarket basket from Hinson, GYT-R, or Barnett.
  • soulsedg3
Posted July 13, 2015 - 03:19 PM
http://www.rekluse.com/zstartpro.shtml
would this be a better idea?   629 for that assembly.
although it doesn't seem to show a basket. hrmm
Edited by soulsedg3, July 13, 2015 - 03:20 PM.
  • soulsedg3
Posted July 13, 2015 - 03:39 PM
oddly enough i'm not finding any GYT-R baskets for 2003?   i see some for 2004/2005....
and if you had a choice between hinson for 346, and barnett for 283, which would you take?
Guessing oem springs as well?
Edited by soulsedg3, July 13, 2015 - 03:58 PM.
Posted July 14, 2015 - 06:23 AM
The '03 does in fact use a different basket.  The '04 aftermarket stuff won't fit because the hole pattern was changed to accommodate changes in the drive cushion design inside the gear assembly.  But you could replace the whole assembly with an OEM '04 basket/gear, too.  Not an '05, though; different gear ratio.
OEM springs.  $57 difference between Barnett and Hinson?  I doubt the Hinson is that much better.
  • soulsedg3
Posted July 14, 2015 - 06:51 AM
Im going to need to get your address and send ya a bottle of booze grayracer. Or a paypal to send some money for a bottle. Haha.
I really appreciate the help.
  • On January 15, 2017
  • 5 replies
  • Hot  113 replies
  • Hot  30 replies
