YZ 450f 2014 Light stator
8 replies to this topic
  • caxuda
Posted July 12, 2015 - 03:49 PM
Hello,
Someone said to me that the yz 450f 2014 can power a motorcycle lighting system with the stock stator
Is it true?
Best regards
  • Monk
Posted July 12, 2015 - 04:42 PM
Yes
But the bike has to be running...
  • caxuda
Posted July 14, 2015 - 01:48 PM
Yes
Really!!!!! Are you sure? I saw that you have a yz 2014+ on your profile image. Do you have one?
That is a very important thing for me to choose to buy this bike because I want to ride it on the street.
  • Monk
Posted July 14, 2015 - 02:26 PM
Unless you mount a battery or such the light will not work without the bike running...Mounting a battery could be easy but you need to fabricate a mount.
  • caxuda
Posted July 14, 2015 - 02:30 PM
Yeah, I know that it hasn't battery. I was asking about the stator, beacuase all the older yz until EFi have not a lighting stator.
  • Monk
Posted July 14, 2015 - 03:21 PM
No such thing as a lighting stator. The 10-13 models could easily support a headlight. I think available output is around 100w. They can power quite a bit. Our bikes use a capacitor which is meant for weight savings over a battery. The capacitor still recharges. You could mount a battery in place and have no issues...
Older units could power a small LED light but available wattage was small....
Edited by Monk, July 14, 2015 - 03:22 PM.
  • caxuda
Posted July 14, 2015 - 03:30 PM
Thank you Monk!
What a nice info you gave to me. I think I'll buy a yz from 2014.
  • bigbird192
Posted July 15, 2015 - 06:09 AM
No battery on this. Works great.
http://www.pro-motio...nload=ntrs2-176
Posted July 15, 2015 - 06:13 AM
The EFI YZ450's have an all-DC system, powered by a 140W (I believe) AC magneto.  You can pick up lighting power directly from the red DC+ lead at the rectifier or elsewhere on the bike.  IF you have a very power hungry light, you may want a switch to be able to turn it off, as it could affect the system's ability to run the fuel pump at kicking speeds without a battery on board.  Some of the aftermarket trail lighting outfits offer a plug-in harness the goes between the ECU connector and the ECU and provides a point to connect lights to.
But, the bike isn't ever going to be suitable for any kind of extensive street riding without a lot of modification.
