Help ? 2010 yzf 450
7 replies to this topic
  • Bikerboy
Posted July 04, 2015 - 01:09 PM
basically flipped the bike and it literally won't start atall or bump no sign of life wondered if it could be flooded ? Don't really no much about these new yzf and not sure if they can be drained ? Or if it would be anything else ?
It's a 2010 Yamaha yz450f
  • dirteta
Posted July 04, 2015 - 01:51 PM
Have you inspected all the wiring? Maybe something came loose or pulled out when you flipped it?
  • Bikerboy
Posted July 04, 2015 - 02:09 PM
I've had a very good look around cant see any obvious signs I will be sure to have a good look again tomorrow
  • The Spanky
Posted July 04, 2015 - 02:11 PM
Pull the plug and see if it's oil-fouled.
  • Bikerboy
Posted July 04, 2015 - 03:45 PM
Will try that Any other suggestions
  • WR250F
Posted July 04, 2015 - 04:03 PM
If you have no spark then I would check your kill switch. What part of the bike hit first. I would check there first.
  • billygildark5007
Posted July 04, 2015 - 05:28 PM
Get a tuner and look for any fault codes as well. If there's a code you can start by checking the ohms on sensors and continuity test the wires/harness
  • Bikerboy
Posted July 05, 2015 - 01:51 AM
Took all plastics off found one of the plugs
Wasn't in its correct places so connected it fires
Up first kick literally but when it's rode its
Spluttering in almost all gears on first quarter
Of the rev any suggestions ?
