WHAT'S THE BIGGEST BIG BORE KIT?
7 replies to this topic
  • arraCODEBLUE
Posted February 20, 2002 - 10:42 PM
What is the biggest big bore they make for the old 426? Who makes it? $? what all MAJOR modifications do you have to make? I don't want to have to make HUGE modifications. The biggest I've found so far is a Wiseco 450cc kit. was wanting like a 500......
  • MN_Kevin
Posted February 20, 2002 - 11:16 AM
http://www.eric-gorr...cylrebuild.html
  • Jon_Escombe
Posted February 20, 2002 - 03:10 PM
The biggest piston I've found is a 98mm JE (453cc). It's a special part made from a TL1000 blank, and a bit more of a pain to install than the regular 97mm.
You can also increase the stroke by 4mm, which will give you a max of 484cc. However, rod life becomes a significant factor...
HTH, JonE.
  • arraCODEBLUE
Posted February 20, 2002 - 03:19 PM
Know anyplace that does that modification?
  • Jon_Escombe
Posted February 20, 2002 - 03:41 PM
I'm in the UK, afraid I don't have any suggestions for getting the parts in the US.
Sadly the British distributor (Phil Allen) passed away a couple of weeks ago, but you could try this German site for info... www.bergos.de
JonE.
[ February 20, 2002: Message edited by: Jon Escombe ]
  • yz454
Posted February 20, 2002 - 08:42 PM
Change the rod to something else I did. The yamaha needs more stroke and a longer rod.
  • John_Lorenz
Posted February 21, 2002 - 05:23 AM
Try
http://www.powroll.com
This guy proved his worth to me many time in the past for Honda strokers. Back in the hayday of XL-250 and XL-350's these were the stuff. The guy does great work. Cant vouch for the 440 yz stroker kit though
  • Ga426owner
Posted February 21, 2002 - 06:58 AM
Be careful, the biggest baddest will also give you the shortest lifespan as others have attempted.
The 450 kit seems to hold up real well.
  • 0 replies
  • Hot  33 replies
  • Hot  47 replies
Motocross
  • Hot  491 replies
