2015 WR 450f
9 replies to this topic
  • KX25O
Posted July 01, 2015 - 04:33 AM
Does the 5 speed transmission get annoying out on the open trails?
  • mch
Posted July 01, 2015 - 05:52 AM
As opposed to what?  My transmission ratios seem pretty good, but at 70mph or so with stock gearing, you feel like upshifting into 6th or 7th (which doesn't exist).
  • Krannie McKranface
Posted July 01, 2015 - 08:40 AM
It's wide ratio, so no.
If you mean why doesn't it have a 6 speed like a KTM, remember, they use close ratio, due to whimpy torque.
  • offrd beatr
Posted July 01, 2015 - 10:37 AM
The ratio spread is ok once the bike is moving. First is too tall and fifth is too short
  • Andrew Puetz
Posted July 01, 2015 - 07:35 PM
to answer the question... no
Posted July 02, 2015 - 09:47 PM
I run 14/50 if it's going to be lots of dual sport. Cruise all day 45-55 mph. 80 max.
13/51 if not. Cruise at 35-45. 70 max
My 6 speed KTM is about the same results because ALL KTM's sinced 2011 are close ratio. No more wide ratio motors. The 5 speed models are like 4 speeds on the Jap bikes.
Beta's are wide ratio 6speed.
The new YZFX is wide ratio 6speed.
  • chu
Posted July 03, 2015 - 05:03 AM
Sounds like if it was like the Beta, you could leave the gearing stock and ride it like a 5 speed.  Then 6th would just be an overdrive gear for the highway.  I'd probably like the ratios a little closer than what we have now and then add another gear.  Either way would be an upgrade.
  • jmd426
Posted July 03, 2015 - 11:01 AM
Lol  :lame:
  • Texas2Smoker
Posted July 03, 2015 - 11:08 AM
I find myself chugging a little bit in the woods and slow trails. I think I'll go up 2 or 3 teeth on the rear sprocket. That should help. The rest of the gears are fine and should be fine even with the lower gearing. If you're coming from a Kawasaki, you'll love this bike. Hell, if you don't love this bike something is wrong with you.
  • chu
Posted July 04, 2015 - 08:34 AM
The gear ratios on the 500EXC don't look too bad on gearingcommander.  The 350XC-F looks like it would be similar to a close ratio 5 speed with an extra shift.  The 350EXC-F has a lower first and second, looks like it would be like a wide ratio 5 speed with an extra shift.
Edited by chu, July 05, 2015 - 06:10 AM.
