YZ450FX IS ON IT'S WAY
Yamaha YZ450F
214 replies to this topic
  • tomerb
Posted June 25, 2015 - 06:32 PM
I just checked CARB and the new YZ450FX is listed on there site!!
  • Krannie McKranface
Posted June 25, 2015 - 06:49 PM
OH
MY
GOD !
:banana:  :banana:  :banana:  :banana:  :banana:  :banana:  :banana:
  • jmd426
Posted June 25, 2015 - 06:53 PM
:ride: :thumbsup: :thumbsup:
Posted June 25, 2015 - 06:55 PM
Ok........
...BUT I FEAR THIS IS JUST A TRAP!!
Edited by KRANNIE, June 25, 2015 - 06:57 PM.
  • xcbuckeyeguy
Posted June 25, 2015 - 07:43 PM
Link?
  • tomerb
Posted June 25, 2015 - 09:07 PM
On-Road New Vehicle & Engine Certification Program
2016 OFF-ROAD MOTORCYCLES YZ450FXG 450 GASOLINE
California Environmental Protection Agency YAMAHA MOTOR CO., New Emission-Non-Compliant Off-Highway
 California Air Resources Board
"RED STICKER"
No info on how many gears
  • stevethe
Posted June 26, 2015 - 04:32 AM
Red sticker that's sucky. :lame: :(
  • SatansReverence
Posted June 26, 2015 - 06:50 AM
Now to wait for that juicy info on the 2016 WR450.
  • RockerYZWR
Posted June 26, 2015 - 07:38 AM
Warming up my checkbook...
Edit - as long as it's not a 270 lb pig...I already have one of those.
Edited by RockerYZWR, June 26, 2015 - 07:45 AM.
  • Summit
Posted June 26, 2015 - 03:09 PM
Tell me it's available in anniversary yellow.....please. That 2016 yzf yellow 450 is the coolest looking bike I've ever seen.
Posted June 26, 2015 - 04:18 PM
I don't care if it's puke green or dayglow pink........
  • patrick2wd
Posted June 27, 2015 - 02:27 AM
hmmm... no news on the WRF450?? :cry:
Posted June 27, 2015 - 04:54 AM
Patience, one must have, young Skywalker.
  • patrick2wd
Posted June 27, 2015 - 05:08 AM
http://<iframe src="...creen></iframe>
Edited by patrick2wd, June 27, 2015 - 05:09 AM.
  • MidlifeCrisisGuy
Posted June 27, 2015 - 09:04 AM
The 2015 WR250F weighed 258 pounds.  The 2016 YZ250FX weighs 249 pounds.  Ie, the WR lost 9 pounds going to the YZFX model.
The 2015 WR450F weighs 273 pounds.   The YZ450FX is going to lose about 10-11 pounds going to the YZ450FX model.  That puts it at 262-263 pounds.   Still a heavyweight pig.  And it still needs a skid plate.
My lightened WR450F weighs a bit over 250 pounds, full of fuel, with skid plate and bark busters.
  • DMC707
Posted June 27, 2015 - 10:07 AM
My only question -- is since the current generation WR450 is already a quite capable mount ----  would a WR based on the YZF really bring anything new to the table?
The WR is green sticker already and potentially more suitable for back woods roaming for a lot of people than a full tilt  YZF based machine aimed squarely at GNCC and WORCS racing
----- Just thinking out loud - i havent rode the current WR  --
I rode an 09 YZF , (and a 2 stroke 250 in select eventS) until 2012 , then switched to CRF-X's for the last 2.5 years ---
Love the blue bikes (or white or yellow )  ---  but i have heard that the tendency to climb out of a rut is still there   -  That was my main gripe with the blue machines, as the red and yellow bikes seem to have the handling down to a science
  • MidlifeCrisisGuy
Posted June 27, 2015 - 10:49 AM
It all boils down to geometry.  Swap in a set of 22mm triple clamps and crank up the preload on the back end, maybe drop the TCs and its an entirely different beast.  KTMs run 20 and 22mm TCs, for the most part anyway.   Most Yamahas are 25mm.
Posted June 27, 2015 - 11:36 AM
No matter what the subject, you have to find a way to work in the weight of your stripped no e-start WR, don't you.
Try this on for size:
The 2015 YZ250FX is 16lbs heavier than the YZ250F
Therefore, the WET WEIGHT of 245 for the 2015 YZ450F, plus 16 lbs, would be about 261 for the FX.
Guess what a KTM 450 XCF weighs wet?  253lbs.  So it's less than 8lbs heavier than a KTM. Most of that additional is in the kickstand and crank and transmission.
WHO CARES
  • MidlifeCrisisGuy
Posted June 27, 2015 - 11:54 AM
Weight, especially high on the bike, makes a huge difference in how they handle.  I've swapped back and forth between my bike and a stock WR450F and the difference is night and day.
Yamaha builds really well built, reliable, economical, powerful bikes.  But their off road bikes are unnecessarily heavy.  If you want a great Yamaha off road mount, build it yourself.  Its not hard and there are tons of parts available, OEM or aftermarket.
Edited by MidlifeCrisisGuy, June 27, 2015 - 11:59 AM.
  • MidlifeCrisisGuy
Posted June 27, 2015 - 11:59 AM
FYI, from what I've heard, the YZ250FX won't start without the battery.   The WR450F will.   I sincerely hope that the YZ450FX will start without a battery, just like the YZ and the WR do.
I'm not exactly sure what the YZ450FX would give you over a WR.  Of course the reverse cylinder engine will probably be a gem.  Other than that, its standard Yamaha fare.
I'm not even sure where the weight loss is going to come from, other than simple things you could unbolt from a WR.  The new engine is probably somewhat lighter.  The frame is probably going to be a YZ250F variant, which is a couple pounds lighter.
A friend of a friend has a YZ250FX.  My friend has ridden it.  He says its nice, but not mind blowing.
Edited by MidlifeCrisisGuy, June 27, 2015 - 12:00 PM.
  • Hot  50 replies
  • Hot  38 replies
  • Hot  113 replies
  • 10 replies
