Where to find white wr headlight
9 replies to this topic
  • yz2009
Posted June 25, 2015 - 02:53 PM
I'm trying to find the entire highlight assembly from a 2008-2011 wr450
Every parts diagram I look at I can find the blue and white one but I can't find the all white one. I know they made it be used they produced a white bike. I just can't find where to buy it. Anyone know?
  • stevethe
Posted June 25, 2015 - 03:34 PM
Nope never made white. Either paint it or get a 2012.
  • yz2009
Posted June 25, 2015 - 03:47 PM
Well I feel dumb now. I guess all the pictures I've seen are either painted ones or really good 3rd party ones.
The 2012+ headlights have a different mounting pattern don't they?
  • stevethe
Posted June 25, 2015 - 04:14 PM
Krannie has a 2012 on his and they are white.
They don't even make a stock type aftermarket in white. I used white plastic paint on my Supermoto.
  • Krannie McKranface
Posted June 25, 2015 - 05:00 PM
2012 fits with a bit of fab
Acerbis or Polysport might make a white one
  • yz2009
Posted June 25, 2015 - 08:55 PM
What kind of fab was needed to make it fit? Im pretty handy but dont have access to anything to make intricate metal brackets and what not
  • foggy3061
Posted June 25, 2015 - 09:42 PM
If you have standard lower triple clamps the 2012 headlight bolts straight on to a 2007 to 2011 wr, no fabrication required.
You will have to change the headlight connector wiring though.
Posted June 26, 2015 - 04:22 AM
I used the 2012 mount brackets too.
  • RockerYZWR
Posted June 26, 2015 - 01:01 PM
I bought a new blue housing from boats.net for around $20, which doesn't come with the white number plate graphic, gave the plastic a good cleaning with paint prep/wax remover, and then gave it four or five coats of Krylon Fusion white.  It held up really well over a full season of desert racing (lots of brush scratching and a few solid wrecks) and has just a small amount of scratching/chipping on the front outer edges of the plastic.  Easily touch-up-able, which is what I will do when I change plastics and graphics later this summer.  So if you prefer the look of the 07-11, which I do, this is a viable and inexpensive option.
I also took some extra graphic material and cut it to add a little color to it, which also helps protect it a little.
vehicles-372959-0-59459000-1408582757.jp
  • fixitandy
Posted June 26, 2015 - 08:24 PM
Apparently you can get an all white WR headlight cowling, check out TT member smackit he has one one his which he got whilst visiting China last summer, & was maybe going back this summer & was gonna try & source me a couple, but my last couple of PM's have gone unanswered hope he wasn't blowing smoke up my butt, as we here in Australia did get an all white WR & a black model but the headlight, although very similar in profile & shape has a larger/ taller lens & a slightly larger/taller number plate/ top section which we call the ADR headlight for road going purposes, so if you try & PM smackit as well we might just make enough noise to awaken him again.
