Mapping to keep from Flame-out with Rekluse 3.0
9 replies to this topic
  • yam314
Posted June 21, 2015 - 08:25 AM
I currently have a '10 YZ450 with a Rekluse 3.0 and FMF slip-on. The bike keeps flaming ut after a sudden throttle chop. I have spoken with the Rekluse rep several times, verified the free-play,and increased the idle speed, but it still stalls, and is very hard to re-start. I think I may need to change the mapping. I am currently running :
  Fuel       Ignition
  0 0 0          0 0 0
+2 0 0        -1 0 0
+4 0 0        -5 0 0
 Any suggestions, as I am new to the mapping, but just bought a tuner.
  • Monk
Posted June 21, 2015 - 09:42 AM
Unfortunately mapping will not cure it. It would require you to send your throttle body to a company like Injectioneering to fully eliminate the problem. Blame the butterfly valve...
What idle speed do you run?
  • yam314
Posted June 21, 2015 - 09:54 AM
Not sure yet on the idle speed, but it is a bit higher than normal. I just got the tuner yesterday, and have not had a chance to check RPM with the motor running
Posted June 21, 2015 - 11:45 AM
Injectioneering was in this early with the 2010 models.  Then complaint then was that "tip-in" throttle maneuvers resulted in a sudden, jerky response from the engine that made rolling the throttle on in a corner or a tight spot an iffy business.  They've gone on to generally improve roll-on behavior and overall responsiveness.  The consensus is that it's worth the money.
  • CG118
Posted June 21, 2015 - 01:59 PM
Try this fat map that is listed as "SMOOTH" for the 2010:
FUEL                      IGNITION
+5  +5  0               0   0   0
+5  +7  +1             0   -5  0
+5  +7  +2             -3  -4  0
I had issues with stalling on my 2015, and used the fattest map I could find-----I haven't stalled yet (even took the bike on a short woods ride).  The power is also very smooth and manageable.
  • Monk
Posted June 21, 2015 - 04:46 PM
FUEL IGNITION
+5 +5 0 0 0 0
+5 +7 +1 0 -5 0
+5 +7 +2 -3 -4 0
15 and 10 are considerably different. I have a 15 with a Rekluse also and 90% of my riding is woods. I honestly don't remember that last time I flamed out as the bike runs so good.
  • CG118
Posted June 21, 2015 - 06:31 PM
No Rekluse here. Just stock clutch. Moto only.
The mapping I listed above is specific to a 2010, not my/your 2015.
Hope it helps yam314.
  • yam314
Posted June 22, 2015 - 04:14 AM
Thanks guys, i will try out those maps. I still need to understand a little better about how each change affects the power.  I ride off-road, as well as MX.It was stalling on the track after braking hard, then trying to hit the throttle hard out of the berm. But I never had these problems before the Rekluse.
Posted June 22, 2015 - 06:46 AM
Try this fat map...
If you're having trouble with flameouts at low speeds, especially during quick throttle closings and such, richer is rarely the right direction to push things.
  • CG118
Posted June 22, 2015 - 08:34 AM
I agree.  Fat fuel maps seem counterintuitive, but that's what is listed quite often for FI bikes' woods mapping.
  • Hot  113 replies
  • Hot  50 replies
  • 0 replies
