Water Pump Impeller removal 05 WRF450
6 replies to this topic
  • BAnd05
Posted June 19, 2015 - 05:36 PM
Hey all,
I've read a lot about needeing to rmove the case to get the impeller out, but also that it can be done with a  wrench while holding the kick starter in place. Anybody here actually got that to work? Not sure which direction to turn?
Total Newb when it comes to repairs here!
  • rah7777777
Posted June 19, 2015 - 06:25 PM
Just did mine last weekend when I put on the Boyesen pump on. 2006 model
Take a ratchet and turn the blades lefty-loosy. As you turn you'll hear the engine spin and notice when it's on compression (gets harder) I put it just to that point and hit the ratchet with a rubber hammer. After hitting and going back to compression a few times and doing over, it broke loose.
I did the same thing to tighten it. All reality I think my dewalt 20v impact would have worked too (I was being lazy as it was inside and I didn't want to go get it)
Posted June 23, 2015 - 10:21 AM
Then there was the guy who broke the drive tang off the impeller shaft because he took a short-cut by leaving the crankcase cover on...:excuseme:
He found the extra $30 expense to be somewhat annoying.
  • BAnd05
Posted June 24, 2015 - 04:56 PM
Thanks for the advice, rah7777777 and grayracer513. I went ahead and ordered a new cover gasket so I will remove the cover after all. I also have an experienced neighbor riding shotgun, so I should be OK after all.
  • rah7777777
Posted June 24, 2015 - 05:56 PM
I didn't even know there was a need to take a cover off. I didn't read any instructions, just dove in. Glad I didn't mess anything up.
Posted June 25, 2015 - 08:53 AM
Water pump replacement:
http://www.thumperta...0-coolant-leak/
  • rah7777777
Posted July 07, 2015 - 05:41 PM
Very interesting. Learn something new everyday.
What exactly can break?
