2008 yz450 suspension question.
6 replies to this topic
  • Keith Z
Posted June 19, 2015 - 02:59 PM
Hi all, I have an 08 450 with stock springs. I weigh 190. I have the sag set at 100mm and the fork and shock compression are turned almost full stiff, but backed out 1 or 2 clicks. I only ride the bike at a track.
The suspension feels good and I don't bottom on any jumps but I was wondering if the suspension would work better if I got heavier springs and was able to back clicker settings to maybe 10 out or so?
Thanks to all who care to reply.
  • OldOkie
Posted June 19, 2015 - 03:06 PM
Is the balance OK? It doesn't want to tilt straight up or kick the rear high when you leave a standard jump? Then good rebound speed and rate. Does it rattle you on breaking bumps?
  • Keith Z
Posted June 19, 2015 - 03:10 PM
Thanks for quick reply. No it feels good and I do a lot of seat bounce jumping. It tracks well through braking bumps and generally feels good, I was just wondering if I'm not utilizing the suspension since i have it set so stiff.
  • OldOkie
Posted June 19, 2015 - 08:08 PM
If it's not rattling you like a paint shaker and you're not bottoming I'd say you're fairly close. I'm a woods guy tho so maybe some of the mx guys have deeper input
  • Wiz636
Posted June 20, 2015 - 08:21 AM
I think at 190 you are on the verge of needing stiffer springs but its probably not crucial.  Talk to a suspension guy.
Have you tried backing out the compression clickers?
  • Keith Z
Posted June 20, 2015 - 08:30 AM
Yeah I have tried backing the clickers back but then the bike bottoms and feels too harsh. I talked to a suspension guy today and I decided I'm going up a rate in the front and rear, he said the suspension will work better since I have the compression cranked in so stiff. Thanks for the help guys, I will report back when I get it done.
  • Krannie McKranface
Posted June 22, 2015 - 02:22 PM
Well, merely changing the suspension oil will make a huge difference in control, as the puke that comes stock in KYB is dead in about 25 hours.....
Yes, a re-spring and a re-valve will make a substantial improvement over the level of ride you have now.
You will be amazed.
  • 10 replies
  • Hot  47 replies
  • On January 15, 2017
  • Hot  36 replies
