Clutch Issues
3 replies to this topic
  • yamahakid426
Posted June 18, 2015 - 04:48 PM
Hello all, so ive done a clutch redo before (aka new plates and springs) but this one is stumping me im a little rusty, basically my clutch was really hard so i got a new cable and adjusted it and it got a little easier to pull but still stiff. i replaced the plates and this is where i need help. Should the bolts on the springs be tightened until they stop and then torque them? when i do that it gets harder to pull. i screwdriver tightened them all the way and then backed them off 2 turns and that made it easier to pull in (still stiff) and the action seemed the same. Can anybody help please? Thanks
  • 03yzf450-kuke
Posted June 18, 2015 - 06:25 PM
Tighten them until they stop and then set them to the proper torque which im pretty sure is 5.8 ft lbs. If you think its too stiff of a clutch buy an ez pull clutch system.
  • yamahakid426
Posted June 18, 2015 - 06:50 PM
Thanks for the help, got it tightened up and just ordered an ez pull system
Posted June 18, 2015 - 08:08 PM
The correct torque is 7.2 ft/lb (87 in/lb)
