front wheel axle removal
2 replies to this topic
  • hempking
Posted February 19, 2002 - 11:32 AM
Is there a trick to removing the front wheel axle,
I removed the nut and backed out the pinch bolts but the axle only moves about half an inch...am I missing something? could my axle be bent?
the axle spins fairly easily and the wheel spins independantly. :)
  • Ga426owner
Posted February 19, 2002 - 11:55 AM
you need to carefully pry open the left side fork bottom, where the pinch bolts are with a chisle or large flathead screwdriver. Then tap out the axle from the right side with a rubber mallet.
  • Sparky_So_Cal
Posted February 19, 2002 - 05:18 PM
Once you get all the pinch bolts loose, you will notice that the axile as a hole in the middle. Get a punch or crappy old screw driver and insert it into the hole in the axle (try to bottom it out). Gently tap w/ rubber mallit, once it moves you sould be able to grab it on the other side.
