Yamaha WR450F questions
27 replies to this topic
  • stevethe
Posted June 16, 2015 - 11:08 AM
#21
Update: didn't end up buying the bike had a massive knocking noise from the bottom end.
They are all pretty noisey. If you pull in the clutch most of the noise goes away.
  • Jack8745
Posted June 16, 2015 - 11:11 AM
#22
Oh really? Held the revs at a steady rpm and it wasn't as loud the knock as soon as I let them drop to an idle it came back took it for a ride and when under load there was a like crunching/grinding noise which made me think bottom end was going?
  • Krannie McKranface
Posted June 16, 2015 - 12:12 PM
#23
You can't typically 'hear' a dying crank, until it's too late.
Usually you are hearing the cam chain or piston slapping around.
  • 270winchester
Posted June 16, 2015 - 01:45 PM
#24
Or the very loud clutch when in neutral (which is normal)
  • stevethe
Posted June 16, 2015 - 04:02 PM
#25
Crunching and grinding don't sound good. However they are noisy at idle until you pull the clutch in and chain slap can also be noisy.
The best way is to listen to another one. The one you rode could have been run with no to low oil.
Edited by stevethe, June 16, 2015 - 05:09 PM.
  • Jack8745
Posted June 19, 2015 - 01:43 AM
#26
Yeah I didn't realise this. Only time I pulled the clutch in when idling was just before I put it in first to test ride it
  • Jack8745
Posted June 19, 2015 - 01:45 AM
#27
I checked the chain thinking it was that but it was quite tight but like you say only way I'll definitely know is if I look at another bike
  • Jack8745
Posted June 19, 2015 - 01:46 AM
#28
Another thing I noticed was in first gear it seemed really bogged down and struggling to go.
