Wrong Friction Clutch Plates: 01 YZ426
6 replies to this topic
  • YZ Yankee
Posted June 15, 2015 - 06:49 AM
i just realized I ordered the wrong friction clutch plates for my 01 YZ426.
I have (8) 5JG-16321 and (1) 3XK-16321
Looks like I am suppose to have (8) 3XK-16321 and (1) 5JG-16321.
Does anyone know if this will still work correctly. It is my undestanding that the one  5JG-16321 has a lager inside diameter to allow the plate to fit over the clutch  boss/springs.
The plates are not returnable.
Thanks for your help.
Posted June 15, 2015 - 08:16 AM
As long as you make sure to install one of the 5JG plates at the back, it should work.
  • YZ Yankee
Posted June 15, 2015 - 08:52 AM
Thanks Gray...
You're local.. do you know any of these guys personally..Lightninquick, Bolt, KennyMc
Posted June 15, 2015 - 08:56 AM
Did some suspension work for Kenny once on his old WR forks, but he's like 150 miles away.  Don't know the other two.
  • YZ Yankee
Posted June 15, 2015 - 04:14 PM
I was wondering cause in some of your post you indicated you work with desert racers..thinking D37..Hesperia area..
Posted June 16, 2015 - 06:17 AM
D38... All the way south.
  • YZ Yankee
Posted June 16, 2015 - 07:37 AM
My way...and past..out of Murrieta.
.D38.. that's Ocotillo Wells area. .Regul8or used to race D38.
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  33 replies
  • 0 replies
