Handlebar Mount Stud
2 replies to this topic
  • tomerb
Posted June 14, 2015 - 07:02 PM
Will the stud in the stock bar mount that goes through the top triple clamp unscrew??
  • chu
Posted June 15, 2015 - 11:50 AM
I think it's a press fit into the lower clamp.
  • tomerb
Posted June 15, 2015 - 01:17 PM
Well I took the chance that they were threaded in with Loctite and put it in some soft jaws in the vice and put torch to stud till it started to smoke and with vice-grips I was able to remove it. It turned out to be a M12X1.25 thread and on that end and it's10mm on the other end. I got some 12mm bolts at ACE to replace the studs so now my spacers would fit under the factory bar mounts.
