03 yz450 valve timing and shim
24 replies to this topic
Posted June 24, 2015 - 01:54 PM
Exactly where the header gasket goes; in the exhaust port.
  • Zach Hanson
Posted June 27, 2015 - 10:35 AM
Okay so I was puting everything back together and now the intake can will not move at all when I tighten it down. I loosened it and re tightened it multiple times but it still won't move!
*intake cam
Posted June 28, 2015 - 06:39 AM
Check the camshaft clearance with Plasti-Gage per the manual.
  • Zach Hanson
Posted July 01, 2015 - 10:07 AM
The clearances look good. When you tighten down the cams, are they supposed to be tight or move freely?
Posted July 01, 2015 - 10:18 AM
Not valve clearance, camshaft to bore clearance.  It is not uncommon to find that the intake in particular will tighten some with the engine cold.  You should still be able to turn it by hand, though.
One other thing, and one that really should not affect this question, is that I have always been uncomfortable using the full recommended torque on the cam cap bolts.  The manual calls for 7.2 ft/lb (86 in/lb) with oiled threads.  Oiling threads results in clamping tension that's about 20-30% higher than the standard, clean and dry threads ordinarily specified, and when I run them down that tight, I don't like the feedback I get from them.  So, I use 75 in/lb (6.25 ft/lb) instead, it feels much better, and in the 12 years I've been doing that, I have had no problems.
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
  • 0 replies
  • 9 replies
  • Hot  33 replies
