wr426 just dies
22 replies to this topic
  • cupcake2100
Posted June 06, 2015 - 06:50 PM
hello i have a 2002 wr426 and it just started dying today. i was riding up in the mountians and it just started dying, it died once right when i tried to put in in gear, it has done this a few other times, then later in the day it would not even idle, it will run if i am giving it gas or i have it chocked but once i stop giving it gas it just dies like i press the kill switch. any suggestions are greatly appreciated thanks so much for all the help you guys give me
  • Krannie McKranface
Posted June 06, 2015 - 07:04 PM
Service the carb
Check your valve clearances
Change the plug
  • Pooley
Posted June 07, 2015 - 06:48 PM
Big changes in elevation require changes in jetting.  Do you typically ride in the mountains or were you in a new area?  You need to lean it out if you go up in elevation due to less oxygen available.
  • cupcake2100
Posted June 11, 2015 - 02:51 PM
it was not very high up, and now that i am down in the place i live in it will not start and when it does it only goes for like 5 seconds and it sounds bad, is that the carburetor?
Posted June 11, 2015 - 04:19 PM
We can't here it, only you can, so we can't tell you what the sound means.
Is the plug dry after it dies?  Fuel starvation.
Is the plug wet after it dies?  Loss of spark
Is the plug black?  Worn out valve guides.
When was the last time the head was rebuilt?
  • cupcake2100
Posted June 11, 2015 - 04:32 PM
i kicked the bike to life today and the engines pitch was lower than usual, i unchocked it and it idled fine, but still lower, after it warmed up a bit i put it in gear it died
i do not know when the head was last rebuilt
Posted June 11, 2015 - 05:49 PM
All this intangable information us useless.
Measure / Test / Report / Repair
Get a service manual and start doing the service intervals.
  • cupcake2100
Posted June 13, 2015 - 07:13 AM
so i cleaned the carb yesterday and fired the bike up and it started after some persuasion, about 10 kicks, and it idled until it warmed up then died, and once the bike was all warmed up i could not get it to start, i dont think that it is the spark plug because i can get it to start, but only when the bike is cold, any suggestions?
Posted June 13, 2015 - 06:20 PM
Yes, GET A SERVICE MANUAL and perform the stator check tests.
  • cupcake2100
Posted June 16, 2015 - 07:07 PM
so i have now cleaned the carb, gas was getting to the carb because it was full of gas and i have changed the spark plug, still the bike will not start, there is spark, i checked when i changed the plug and the engine will fire once or twice when i kick the bike, but it will not start, any suggestions?
Posted June 16, 2015 - 07:25 PM
What exactly do you mean when you say 'cleaned the carb' ?
  • cupcake2100
Posted June 23, 2015 - 01:34 PM
hello i was wondering if this could be a vacuum leak with the carb, is that possible?
Posted June 23, 2015 - 02:35 PM
The carb has no vacuum lines.
  • cupcake2100
Posted July 08, 2015 - 01:01 PM
ok so i took the bike in to a professional and he fixed it, i guess i didn't clean the carb correctly  :facepalm:  so today after i get the bike back im riding it and it died again when i stop using the throttle, and it is hard starting, the strange thing is that it was running great for a few hours after the professional fixed it, any suggestions?
Posted July 08, 2015 - 01:37 PM
Really?
  • cupcake2100
Posted August 09, 2015 - 06:32 PM
hello! my wr426 still refuses to idle, the only way to make it idle is to turn the idle screw up a little too high and this makes it overheat faster, when i got the carb cleaned the guy that did it said that one of the jets ( i dont remember which one) was smaller than the stock jet, he said that this was not much of a problem, but im not convinced, could this be what is keeping the bike from idling? also the bike idles fine when i go to a higher altitude. thanks for all of your replies krannie i really appreciate it!
Posted August 09, 2015 - 07:32 PM
Yes
Take it back and tell him to do it right.
You should have a 45 pilot jet
Remember this is an old bike with an old carb, so the needle jet, slide plate, slide plate seal, apump diaphragm, are all worn out and need to be replaced........if you want it to run well like a stock bike.
  • cupcake2100
Posted August 10, 2015 - 08:07 AM
thanks! another thing that started happening yesterday is that gas is constantly dripping from one of the many hoses coming out of the carb, it just started doing this yesterday, the only thing that i have done differently is i went dirt biking up in the mountains two days ago, is the float in the carb dirty? i just had it cleaned
Posted August 10, 2015 - 12:41 PM
Whoever is working on your bike is an idiot.
  • cupcake2100
Posted August 11, 2015 - 01:07 PM
do you think that the float is dirty?
