2013 yz 450f runs rough at steady throttle, but fine everwhere else.
9 replies to this topic
  • Jonell
Posted June 04, 2015 - 08:23 PM
Bought this bike used a couple days ago from local yamaha dealer. Has low hours, but seems to run really rough when i'm not on the gas.  Any ideas would be appreciated!!
This is my first post on TT, but no doubt not my last..
Thank you for your time.
Edited by Jonell, June 04, 2015 - 08:24 PM.
  • dirtbeater
Posted June 04, 2015 - 09:05 PM
Clean the carb is the first thing that comes to mind. Cheap also.
  • 03yzf450-kuke
Posted June 05, 2015 - 02:30 AM
I dont know much bout the newer bikes but try unplugging the tps and see if it changes anything
  • yzdaddy
Posted June 05, 2015 - 03:50 AM
If you just bought it take it back to the dealer. Is it your first efi bike?
  • yzdaddy
Posted June 05, 2015 - 03:51 AM
What if it doesn't have a carb?
  • 03yzf450-kuke
Posted June 05, 2015 - 04:14 AM
On the older ones when it runs rough at only a steady throttle is usually a tps problem. I would start by unplugging it and see if that cures it. Dunno if its same as tge carbureted ones though but worth a try
  • dirtbeater
Posted June 05, 2015 - 04:20 AM
Wow. I am stupid and didnt see the year. My bad. I will go hang my head in shame.
  • Jonell
Posted June 05, 2015 - 07:13 AM
Just spoke with the mechanic at the dealerership, says he's never heard of that before, told him i'm going to try some fuel injector cleaner in it tommorrow and if that doesnt help then i'll unplug the  tps as you guys suggested and see if that helps.  He also said former owner may have been playing with the map settings. Now I just have to try and locate the tps
Have to work all day today so it'll have to wait until tommorrow.
  • Jonell
Posted June 05, 2015 - 07:17 AM
Yes YZDaddy, it is indeed my first efi bike.
Posted June 05, 2015 - 09:11 AM
Unplugging the TPS on a carbed bike disables the 3 dimensional timing map, wherein timing is adjusted both by RPM and throttle position (engine load).  Unplugging the TPS on an EFI system will disable fuel delivery along with that.
Get access to either the tech scanner tool at the shop, or a GYT-R Power Tuner, then interrogate the ECU for trouble/fault codes.
  • Hot  47 replies
  • 10 replies
  • Hot  50 replies
  • Hot  113 replies
