2007 yz450f clutche problem
4 replies to this topic
  • mxking390
Posted May 28, 2015 - 09:38 PM
Okay I need someone to tell me is the clutch plates thicker in the 07 then in say the 06 bc I bought a clutch kit and it came with too mean and the plates where a lot thinner and lighter than mine I know they changed the set up so I'm guessing the 07 has a thicker clutch plate to make up for the difference if plates and fibers please tell me so I can get back to ridding thanks
  • WALKINGWOUNDED
Posted May 28, 2015 - 09:45 PM
I would post your question in the Yamaha specific forum.
You have a better chance of getting a specific answer.
I'm not a grammar Nazi, but I would use proper punctuation and grammar, and be very specific/clear of what you are looking for.
The Yamaha crowd is tough.   :jawdrop:
  • mch
Posted May 28, 2015 - 09:56 PM
Looks like the 06 is not the same as the 07.  I have an 07 and my clutch kit is this one http://www.partzilla...001G-10-00.html
and it does not mention it being the same as the 06.
Posted May 29, 2015 - 07:03 AM
The friction plates are the same, but the steel plates in the '07 are thicker at 1.5-1.7 mm than the '06 (1.1-1.3 mm).  That's why the kits are different.  The thicker plates were used to adjust the stack height when the clutch went from 9 friction plates to 8 in '07.
  • mxking390
Posted May 29, 2015 - 09:33 AM
Okay that's what I thought I needed someone to reassure me thanks grayracer I just ordered the new kit should be correct this time wish me luck
