14 Yz450. What can I do to smooth the power out ?
55 replies to this topic
  • kx06
Posted May 25, 2015 - 07:03 AM
Already put a different map in the bike and went up a tooth on the rear sprocket. Any suggestions mapping etc. ? I ride MX only , always ride 250f and this bike has a ton of power and it's wearing me out
  • BGoyins
Posted May 25, 2015 - 07:22 AM
Try a smaller sprocket like a 48 tooth.
  • 15thumper
Posted May 25, 2015 - 07:46 AM
Dont up a tooth go down bigger in rear makes more torque harder hit
  • 03yzf450-kuke
Posted May 25, 2015 - 08:07 AM
Can you add a heavier fly wheel?
  • GHILL28
Posted May 25, 2015 - 11:34 AM
MXA map and run a gear higher with a tiny bit of clutch work.  It'll fly.
  • yzdaddy
Posted May 25, 2015 - 12:03 PM
Ghill28 is right. You cant ride a 450 like you do a 250. If you try manhandling the 450 your gonna have to be in really good shape and be prepared to hit the ground at epic speeds. Short shifts and a smattering of clutch as necessary.
  • tjg53
Posted May 25, 2015 - 01:58 PM
Flywheel will help , and my be a remap too. The flywheel will make smother , thats what i did on my crf 450.
  • kx06
Posted May 25, 2015 - 05:35 PM
What MXA map? So go back to the 49 tooth rear ?
  • GHILL28
Posted May 25, 2015 - 05:55 PM
Look up the review MXA did of the 2014. They included a recommended map. Lots of oomph.
  • guntoter535
Posted May 25, 2015 - 07:18 PM
Going up a tooth causes more low end hit. The 15 had smooth power and uses a 48. So a 48 rear sprocket and a smoother map.
  • yzdaddy
Posted May 26, 2015 - 04:24 AM
Every 450 I ve owned since the 03 seem to like an extra tooth or two on the countershaft
  • wes513v
Posted May 26, 2015 - 05:44 PM
I would also suggest you look into the Dr.D NS-4 slip on. I added one with the stock map and it smoothed the bottom nicely and felt like it pulled stronger through the mid. Dr. D also can supply you with a map for their pipe that you can try.
  • yzdaddy
Posted May 27, 2015 - 04:37 AM
Tell us the truth Wes you pulled a big ass digger and had to buy a slip on lol
  • jcm3
Posted May 27, 2015 - 06:35 AM
Pulled an RV.  :ride:
I agree with Wes.  I have the Dr D setup on mine, and it doesn't seem to hit on the bottom like my 2011 YZ450 did.  It does feel smoother, and pulls harder higher in the rpm range.
  • GHILL28
Posted May 27, 2015 - 06:38 AM
Got one to unload if anyone wants. Was keeping as a spare because I liked the low end hit of the stocker so I put a sparky on that instead. If I ever RV myself I can have a spare..
  • wes513v
Posted May 27, 2015 - 11:10 AM
I'm too slow to take digger, more likely I tipped because I was moving too slow!
  • yzdaddy
Posted May 27, 2015 - 03:22 PM
Are you ridin on stock suspenders?
  • wes513v
Posted May 27, 2015 - 03:47 PM
Heck no! I'm slow but I like my ride plush. They were done by Shock Therapy a week after I brought her home. Stock was good, re sprung and valved, priceless.
  • kx06
Posted May 27, 2015 - 04:21 PM
[quote name="GHILL28" post="12439115" timestamp="1432737511"]Got one to unload if anyone wants. Was keeping as a spare because I liked the low end hit of the stocker so I put a sparky on that instead. If I ever RV myself I can have a spare..[/quote
Is it a full system ? How much ?
  • kx06
Posted May 27, 2015 - 04:24 PM
Full system ? How much shipped to Michigan ?
  • 10 replies
Motocross
  • Hot  491 replies
  • Hot  113 replies
  • Hot  50 replies
