Accelerator pump spring!
6 replies to this topic
  • Anthonycacia
Posted May 24, 2015 - 02:16 PM
How do I remove the accelerator pump spring to replace it? I got a Tokyo mods spring but can't remove the stock spring for the life of me!
  • Krannie McKranface
Posted May 24, 2015 - 02:22 PM
The rear spring stays
The new spring replaces the front spring
You have to pull the black arm off to replace it
  • Anthonycacia
Posted May 24, 2015 - 07:35 PM
I figured as much, the black arm will not come off, how is it removed?
  • RMK800
Posted May 24, 2015 - 07:47 PM
Have you removed the small lock washer on the top of the black arm goes on? Have you removed the pump rod from it? Pop the rod out if you haven't, grab some pliers and give it a quick tug. If you have then you just need to pull and wiggle it out.
Edited by RMK800, May 24, 2015 - 07:50 PM.
Posted May 24, 2015 - 07:49 PM
You have to remove the pump rod, and the circlip holding the black lever
The pump rod removes by pulling it straight down very quickly.....it's a snap-in fit
  • Anthonycacia
Posted May 25, 2015 - 03:52 AM
I have removed the lock washer, and attempted to pull the pump rod out it wouldn't budge. Now that I know it is infact the pump rod that comes out and the black clip should slide right out I'll give it another good tug hopefully not to break anything, after this I will have all my upgrades in, and my new 07 should be finally running after months!
Thank you guys I'll give it another shot!
  • Anthonycacia
Posted May 25, 2015 - 07:13 AM
Got it! Thanks guys
